09-10-2011, 09:08 AM | #1 |
Quarry Creeper Join Date: Nov 2010 Location: right here!
| I give up. . brushless esc and motor going faster in one direction
Purchased a speed passion esc combo here on the forum and somehow it goes faster in one direction. If throttle is on REV the reverse will be faster and when on NORMAL the forward will go faster. Im tired of searching and hoping you guys can help me out.
09-10-2011, 09:23 AM | #2 |
Have you verified everything on your radio is set to zero, then recalibrated your ESC to your radio?
09-10-2011, 09:41 AM | #3 |
Quarry Creeper Join Date: Apr 2008 Location: Hiding the bodies
^^^What he said^^^. EPA's if you have them to 100% and throttle trim to 0, then recalibrate the esc.
09-10-2011, 10:02 AM | #4 |
Sounds like there is some advance in the ESC. Check your settings there.
09-10-2011, 03:55 PM | #5 |
Recalibrated it back to zero but still the same results. It came with a programming card and you can adjust timing and alll but I dont want to mess with it yet. As far as I know in a brushless if on direction is fast then the other direction should at the same speed IF timing wasnt messed around with. Im starting to think speed passion sucks haha.
09-10-2011, 04:21 PM | #6 |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
My losi ESC and my Novak ESC in both of my crawlers do the same thing.. It's only a minor difference, but it's there. Tried everything . Sent from my highly abused iPhone using Tapatalk |
09-10-2011, 06:30 PM | #7 |
| This one a significant difference. Lets say one direction will go 10 MPh and the other direction will be cut more than half. ITs driving me nuts.
09-10-2011, 07:52 PM | #8 |
Try setting the timing to 0...
09-10-2011, 09:44 PM | #9 |
Tried timing. I noticed that even swithcing from rev to normal itll be forward faster and reverse slower and switching it again reverse will be faster and forward slower. Its seems to be faster when pushing the throttle like when opposite when pulling the trigger of a gun. Sorry thats my best explaination BUT i know for a fact its not the motor because I hooked up my known woring order velineon and its the same results.
09-11-2011, 12:41 AM | #10 | |||||
I can only assume your talking about the transmitter (Tx) at this point. So your throttle trim is at zero, and EPA's (if you have them) are at 100% in both directions, and sub-trims (if you have them) are also at zero? Quote:
On a Velineon, in 'race mode', you're actually in a profile that features forward 100%, and reverse is at 0%. Does your Speed Passion have profiles you can select from? (Perhaps maybe one being 100% forward power and 50% reverse power?) Also keep in mind if I use my Castle Link to turn the reverse down 50% on my Mamba Monster, then I sell it to you, there are no profiles to choose from, but you'd put it in and find you only had 50% reverse power. Did someone previously program the thing to lowered reverse power?(if that can even be done) Then there's the subject of mechanical timing. Did someone dial some mechanical advance into that motor (say for maybe a direct drive/pan car application), and now that you're running it in a gearbox application the timing is on the wrong side of center? (again, if that's even possible with this motor) Just with the field card? (programmed) Or on the motor itself, too? (mechanical) Quote:
So when your truck is finally going fast forwards and slow reverse (I can only assume that's what you're looking for it to do), in order to make your truck do that you hafta 'push' the throttle trigger? So you're just looking to reverse the rotation of the motor? Does your programming card/box have a selection for that on there? If not, you'd need to go back and answer my first question of is it sensored or not? Quote:
09-11-2011, 01:26 AM | #11 | |||||||
09-11-2011, 07:59 AM | #12 |
I hate to say it but it sounds like either a ESC setting or radio setting since it does it with 2 different motors. What radio are you using?? Some radios have throttle trims as well as subtrims, also EPA's. If any of these are different between "forward" & "reverse" you will get what you are seeing now. Same for the ESC, there can be different profiles for "forward" & "reverse", don't assume the seller got it all right before shipping. |
09-11-2011, 07:59 AM | #13 |
Updates..... after almost 2 days of messing with it and ive got some results. I got it to a good speed but its all opposite. Instead of pulling trigger for forward im pushing and the truck will go forward and instead of drag brakes activating when forward its on reverse. Lastly, double tap is when im tyring to go forward not on reverse. I tried many many times recalibrating but this is the best results so far. I tried switching from NOR to REV but that doesnt work out. The truck will just go on its own. I will be giving speed passion a call perhaps they can help me out too. By the way you guys think if i put on a sensorless motor and reverse the teminals itll solve everything. Dont wanna pull the other truck apart and get the same outcome. |
09-11-2011, 08:32 AM | #14 |
You can always swap 2 of 3 motor wires to reverse it's rotation. The "double tap" sounds like you need to do some setting of the ESC to "instant reverse". |
09-11-2011, 09:07 AM | #15 |
| Tried it but no luck. Its a sensored esc its just does stupid things like its tyring to turn spur gear but wont turn it. It hink youre talking about sensorless motor.
09-11-2011, 09:26 AM | #16 |
09-11-2011, 11:12 AM | #17 | ||||
Honestly, yes. That's why I was asking if it was sensored, because I was going to suggest exactly that, throw your Velineon in and reverse two leads. Just make sure at least one of the motor leads matches up, and swap the other two (otherwise you're just shifting phases, not really reversing anything) | ||||
09-11-2011, 07:28 PM | #18 |
Rock Stacker Join Date: Aug 2011 Location: Canada
When you were adjusting the timing with the program card, did you look at any other options? Option 6 on the Hobbywing based Speed Passion ESCs is Reverse force, and you would want it on the fourth setting for 100%. Option 11 is supposed to be rotation direction, but it might be related to dynamic timing depending on the model and firmware; check your card to be sure. If that doesn't help, try disconnecting the sensor harness and run it unsensored, then swap two wires to see if the speed difference changes rather than taking the motor out of another vehicle; swapping wires around in sensored mode is not recommended. |
09-11-2011, 09:21 PM | #19 |
There must be a way to calibrate the esc to the radio signal. Once you reverse it that is what you need to do and it wont go by itself.
09-12-2011, 03:13 AM | #20 | |
