09-10-2011, 11:44 AM | #1 |
| Never buy turnigy lipos!
I purchased 2 Turnigy Nanotech 5000mah 2S 25C lipos off HobbyKing...finlly got a chance to burn through a couple of packs. Temps only hit 100 degrees after each run. After that the cells would not balance when charging. I have to use my Hyperion 0606i to NiMH mode for a few seconds and then switch to Lipo mode and charge. Anyone else experience this? I'm about to contact HK do they have some sort of warranty? |
09-10-2011, 12:07 PM | #2 |
RCC Addict Join Date: Nov 2004 Location: union
I have had around 15-20 of their packs. Zero problems here.
09-10-2011, 12:08 PM | #3 |
Oliver Custom Knives Join Date: Dec 2007 Location: Bloomfield NM , not something stupid
I've had about 15 of them from the 900 to 1300 range , a few puffy issues but never a balance problem.
09-10-2011, 12:10 PM | #4 |
Rock Crawler Join Date: Mar 2009 Location: Grand Jct.
x2. For the price I've been really happy with them and have had better luck than with hyperion.
09-10-2011, 12:15 PM | #5 |
Quarry Creeper Join Date: Oct 2010 Location: Ukraine
Never had any probs with them using 2s. nevertheless i've switched to 3s 3g hyperion |
09-10-2011, 12:19 PM | #6 |
Quarry Creeper Join Date: Sep 2010 Location: Big hands, Little tools.......GRRRRR
Yes. They have a return / warranty policy. Here's the catch. You need to register that you received them on their website within a certain amount of time of you receiving them. I think it is 30 days. My friend did not do this and was rewarded with a LiPo paperweight. He has bought 4 batteries from them. 1 was bad. A 25% failure ratio is not good in my book. Hope this is not bad news for you, and good luck. Last edited by Team Tactical Bacon; 09-10-2011 at 12:21 PM. |
09-10-2011, 12:40 PM | #7 |
Rock Stacker Join Date: Jun 2007 Location: Norway
I have a lot of Turnigy Lipos, both 2 and 3 cells. Using them in crawlers (from Losi Micro to 1:10) and in my Short Cource Slashes (2 and 4wd). No problems at all. Some of the Lipos are very old and everyone is well balanced also when drained to cut-off limit. I'll probably not use any other Lipo - price taken into account.
09-10-2011, 12:42 PM | #8 | |
DOOH!!! Join Date: Feb 2007 Location: AZ
"After that the cells would not balance when charging" Are they tripping the alarm as soon as you plug them in, OR are they tripping the alarm sometime during the charge cylce? Because this : "I have to use my Hyperion 0606i to NIMH mode for a few seconds and then switch to Lipo mode and charge" Sounds like your pulling the battery below the cell limit during run and trying to zap it so it doesn't trip a low voltage alarm at the beginning of the charge. I'd double check you voltage cutoff on your ESC. | |
09-10-2011, 12:51 PM | #9 |
Rock Crawler Join Date: Aug 2009 Location: Sandy Oregon
I have been using the HK batteries (Turnigy, Zippy, Flight Max, Rhino) for over 4 years now and in all that time and close to 100 batteries have only had one that had a bad cell.....for the price they can not be beat! The problem is likely in the way you run and charge them or with your electronics settings....not the batteries |
09-10-2011, 01:33 PM | #10 | |
Was the air temp 100 too? I have never had a pack come off that warm even when overgeared. | |
09-10-2011, 02:53 PM | #11 |
Quarry Creeper Join Date: Oct 2009 Location: Athens
What do you have your LVC set to?
09-10-2011, 03:14 PM | #12 |
Newbie Join Date: May 2011 Location: texas
| not so
i use the same brand, but about 50 c and never had a problem, i have about 200 runs on mine and i push them on a big brushless moters. they still balance fine. the high c is were its at.
09-10-2011, 03:17 PM | #13 |
Another positive experience here. I've had about 15 or so turnigy packs from 2s-4s with my only issues being user operator errors. Apparently I'm on the lucky side to this day. x2 on the curiousity about the nimh mode. The only time one would need to do that is because of running it down past 3.0vdc per cell and the charger wouldn't recognize the pack. |
09-10-2011, 03:27 PM | #14 |
Yea I probably have close to 20 packs of varying age up to 2 years old and all of them are going strong. Sounds like you LVC is too low.
09-10-2011, 07:56 PM | #15 |
Rock Crawler Join Date: Oct 2010 Location: triad
i have a hunch it's not the battery. I have had great results with my turnigy lipos. If you don't have your low voltage cutoff set right, you will ruin them right out of the gate by running them to low. That's what it sounds like is happening.
09-10-2011, 08:00 PM | #16 |
I wanna be Dave Join Date: May 2006 Location: akron
User error.. I own plenty of turnigy packs as well and no issue with balancing.. sounds like you are over discharging the packs.. |
09-10-2011, 08:07 PM | #17 |
I have 2 of their 4000mah 30C 2s packs that work awesome in my go fast bashers. One has puffed a little and started to split the plastic casing, but it works fine and still takes a fulll charge. I have 3 of the 5000mah 20C 2s packs for my scaler that have been submerged many times and still function fine. I also have 3 of the 2200 20-30C 2s pack for my crawler that work very well. For the money, it is hard to complain! |
09-10-2011, 08:15 PM | #18 |
Rock Stacker Join Date: Jul 2011 Location: Leon Valley, TX
guess you shouldn't have titled your thread this way...just sayin'...I don't personally use them but I have plenty of friends that trust them in their planes, a lot to be said for that...
09-10-2011, 10:37 PM | #19 |
Wow lots of replies! I'm using the Turnigy Nanotech 2s 25C lipos on my Losi XXX-SCB outfitted with Castle's SCT 1410 3700kv combo. Outside temperature was around 95 degrees. ESC temp after a full pack was 126 degrees and the motor was at 114 degrees so nothing was overstressed. Lipo batteries hitting 100 degrees isn't too bad of an issue it was still warm to the touch and it wasn't even puffed. The weird thing is one of them puffed several hours later. I guess I need packs with at least 35C? |
09-10-2011, 10:45 PM | #20 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
I have 5... No issues....all my issues in the past have been user error/stupid crap. for turnigy |
