09-13-2011, 07:07 AM | #1 |
Rock Stacker Join Date: Oct 2010 Location: Baton Rouge
| Throttle Glitching
Setup: Futaba 3pm Novak Rooster Crawler ESC Novak 55t Pro brushed HiTec-HS 7950TH 2 cell 7.4v 2300maH Lipo Situation: I've been running this setup for a little over a year now. Just recently started having problems while running my buggy. While sitting still with no throttle input, I can steer left or right and the motor will glitch either forward or reverse. Can someone help me out and explain to me what might be going on. |
09-13-2011, 10:08 AM | #2 |
Your packs may be starting to show their age, when you load up the steering you get a voltage drop that glitches either the ESC or the RX. Running an external (like a CC 10A BEC) should fix this or Getting new packs. I suggest the BEC since it fixes a number of issues at once as well as improving servo performance. |
09-13-2011, 03:29 PM | #3 | |
Castle Creations 10amp BEC, I'll try it. Quote:
