Thread: Question?
Old 09-20-2011, 06:12 PM   #1
Default Question?
I have bought a Integy pro ss crawler and the front motor pulls harder than the rear and reverse the rear pulls more than the front whats up with that? Im just getting in to this crawler rc stuff I have a traxxis slash its way more simple to figure out things...im a DA....
jamesjr38 is offline   Reply With Quote
Old 09-20-2011, 06:33 PM   #2
The rear motor rotates in reverse, both motors are timed for foward. If the endbells are turnable you need to twist the rear motor an equal distance the from zero in the other direction or twist both motors to zero.
indiana mudcat is offline   Reply With Quote
Old 09-20-2011, 06:49 PM   #3
+1, you need to change the timing on the rear motor at a minimum. No big deal, easy to fix.
Charlie-III is offline   Reply With Quote
Old 09-21-2011, 02:38 PM   #4
Thumbs up Thanks guys!
yep that make sence.... what do yall think about a axial wraith? i might try to get one....looks cool....
