09-21-2011, 01:24 AM | #1 |
Rock Crawler Join Date: Mar 2008 Location: 920 Valley of the Fox
| Reverse motor direction on MMP
Just got a MMP & 13.5 DTX sensored motor in my Wraith. I don't have a castle link yet. (thought all I needed was a USB for the Mamba, got a coupon for a free adapter though...) Can I swap the wires to switch motor direction?. I tried a dozen times to switch it on the Tx but no go, recalibrate to ESC...same thing pull trigger get reverse... I'm not sure if it is ok to swap the wires on a sensored motor or even a B/L for that matter?
09-21-2011, 03:07 AM | #2 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
As far as i'm aware you cant do that with a sensored motor because the hall effect sensor needs to be reversed as well (which you cant really do easily). The only way to do it is through castle link/field link. |
09-21-2011, 06:40 AM | #3 |
Rock Crawler Join Date: Oct 2010 Location: triad
do you have a usb cable for a camera or another accessory? That's all it is..... just see if you have a USB cable laying around that will fit.
09-21-2011, 07:15 AM | #4 |
Pebble Pounder Join Date: Jan 2008 Location: westfeild IN
This is being discussed 9 threads down... Timing Changes & "Boost" on Brushless Motors Flip your gears In the axle... |
09-21-2011, 07:33 AM | #5 |
| Older MM's use the USB port (I have 2 of them), I believe the newer ones use the same adaptor as the BEC to program.
09-21-2011, 07:58 AM | #6 | |
thanks for the link I tried searching for this, I knew I read that someone was having similar issues... I really hope I don't have the timing issues he had, I noticed reverse was much faster too... | |
09-21-2011, 09:00 AM | #7 |
Rock Crawler Join Date: Nov 2009 Location: bolivar mo
I jst did that. Use the link and your set.
09-21-2011, 09:40 AM | #8 |
| If you have access to a "link" awesome! I have a relatively new MMP (about 9 months old) and purchased the CC link only to find out when it arrived it's the same USB cable as my camera just a little longer. |
09-21-2011, 10:24 AM | #9 | |
Since my son & I have both CC ESC's & CC BEC's (multiples of each), the whole CL works for us. | |
09-21-2011, 12:28 PM | #10 |
Quarry Creeper Join Date: Oct 2010 Location: Grandview, IA
Leave the center motor wire connected to the center Esc wire. Then swap the A and C wires to reverse motor direction. Have had no problems doing this with my MMP + Speed Passion motor combo.
09-21-2011, 12:30 PM | #11 |
09-21-2011, 01:12 PM | #12 |
Yeah it's sensored, Speed Passion only makes sensored motors. Yes it stayed in Sensored mode. With sensorless you can swap any 2 wires to reverse motor direction, with sensored the center wire has to be plugged in to the center Esc wire while the outside two wires can be swapped. |
09-21-2011, 01:52 PM | #13 |
| You know, you are right!! My bad, i totally forgot about that little board! I just remember getting the cable and thinking i already have like 5 of these laying around. |
09-21-2011, 02:09 PM | #14 |
| Yeah the cable is a standard USB to mini USB yet Castle doesn't exactly make that obvious when buying the Link itself. Then sells their cable for $10 which is a bit steep
09-21-2011, 08:52 PM | #15 |
09-21-2011, 09:24 PM | #16 |
| I'm well aware of this, I have an MMP aand Castle Link. The trick is they give you the Link for free and don't tell you the cable is common and see if you'll buy one from them for $10 when it's a $2 cable.
09-21-2011, 09:39 PM | #17 |
I've seen usb cables at the dollar store... It was nice on the older Mamba's it had the port on the ESC, no adapter needed.
09-22-2011, 01:38 AM | #18 | |||
Well I tried this and it just made weird noises and wouldn't move... IDK how this worked for you federally but no go for me | |||
09-23-2011, 06:00 PM | #19 |
Castle link fixed it! Thanks Kasper for letting me borrow your CL |
