Thread: My battery arcs when I plug it it, am I doing damage?
Old 10-03-2011, 06:47 PM   #1
Default My battery arcs when I plug it it, am I doing damage?
Running dual fxrs, a cc bec and a 3s lipo with deans plugs.
Every time i plug the battery in it arcs at the deans plugs, am I doing any damage?
Maybe if I run an on/off switch on the bec along with the switches on the fxrs?
Just curious,
Thanks
-Matt
Matt, is offline   Reply With Quote
Old 10-03-2011, 06:48 PM   #2
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
That is normal, don't worry about it. It is the capacitors charging up.
JohnRobHolmes is offline   Reply With Quote
Old 10-03-2011, 06:53 PM   #3
Awesome! Thanks for the help!
Old 10-03-2011, 11:37 PM   #4
I no it's not harmful and it's normal and all that, but I've tried hooking up my deans at an angle when installing a batt. for example approach with the Neg. side making contact first and then the pos. I've noticed less popping (arcing) this way. It doesn't take a lot of angle, just touching one side slightly before instead of both simultaneously.
hope that helps
rockhugger is offline   Reply With Quote
Old 10-04-2011, 08:05 AM   #5
You get a better spark using bullet connectors.
Not a problem it's just the capacitors saying "I'm here for you."
AreCee is offline   Reply With Quote
Old 10-04-2011, 04:03 PM   #6
Chassis & Tubework Vendor
I get a nice spark along with the "pop" sound every time I plug in 6s. But never much with 3s.
MG200 is offline   Reply With Quote
Old 10-04-2011, 04:23 PM   #7
watched a guy plug in 12s to his t700 3d heli... that shit scared the hell out of me. but it was cool. nice big arc and loud ass pop!!!
kaneohecrawler is offline   Reply With Quote
Old 10-05-2011, 01:20 AM   #8
Holy crow, 12s must take a wicked expensive charger!
I try to plug the negative bullet first to reduce arcing.
multi-bash is offline   Reply With Quote
Old 10-05-2011, 08:59 AM   #9
You should see the arc on 20s lipo. That is what my ebike runs. With normal power capacitors it is pretty loud. With a larger bank of low ESR caps it will pretty much destroy a plug in one shot, so we have to use a precharge circuit to avoid such welding events.
Old 10-05-2011, 09:05 AM   #10
ebike!? 20s lipos!? i wanna see this!!!
ohh EPiC FAiL is offline   Reply With Quote
Old 10-05-2011, 09:14 AM   #11
Here is a ride on 18s. Holmes Bikes 66v ride - YouTube I killed that battery by leaving it plugged in by accident, drained it to zero. So now I ride 20s.
Old 10-05-2011, 09:34 AM   #12
I think ya ran a stop sign or two in that clip!
msd44 is offline   Reply With Quote
Old 10-05-2011, 09:44 AM   #13
Any bike with a Ammo Can bolted to the handle bars is ok in my book.
1320Fastback is offline   Reply With Quote
Old 10-05-2011, 10:03 AM   #14
That was on a closed course ;)
Old 10-05-2011, 04:47 PM   #15
pffffff... people who ride bikes dont have to obey those types of rules duh!
That thing is seriously awesome
jevyguy is offline   Reply With Quote
Old 10-05-2011, 05:40 PM   #16
that is awesome!
