10-09-2011, 05:47 PM | #1 |
Rock Stacker Join Date: Aug 2007 Location: in a house
| 3 racing winch help
so i just got a 3 racing crawler winch for my crawler, what i was wondering is there is a button on a control pad that u have to push and the winch go's you push it again it go's off. so i was wondering if there is a way i can set it up so i can control it from my controler. i have a m11 with spektrum system sr3000 resever |
10-09-2011, 05:56 PM | #2 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
You need a 3 channel radio and reciever, is the one you have 3 channel? After you do plug the winch controller into the reciever and the battery.
10-09-2011, 08:29 PM | #3 |
I don't think the control board can handle 3s,so you'll need a bec to limit voltage if your running 3s. mine was wired into battery leads,on 2s worked fine,but plugged in a 3s battery and fried the controller instantly...so heads up on that,sony cup like I did. |
