10-11-2011, 10:40 AM | #1 |
Pebble Pounder Join Date: Aug 2011 Location: phoenix (Ahwatukee)
| Should I add a BEC to a wraith on 2s?
Got a new HT servo, wondering if a BEC would help give it more power. I'm running 2s. What should I use?
10-11-2011, 10:42 AM | #2 |
RCC Addict Join Date: Oct 2007 Location: gervais
When in doubt, bec it out lol Either that or I think you could possibly wire your lipo directly to the servo, since it's only 2s |
10-11-2011, 11:12 AM | #3 |
Newbie Join Date: Sep 2011 Location: Germany
wire your lipo directly to the servo.. you don t need a BEC.. |
10-11-2011, 11:13 AM | #4 |
Pebble Pounder Join Date: Aug 2011 Location: Geneva, MN
I'd use a bec. Isnt a fully charged 2s like 8.4 volts and I'm not sure but I don't know any servos that can handle that. Even my high voltage is only 7.4 or 7.2 can't remember. I'd use a bec
10-11-2011, 11:25 AM | #5 |
| 2s lipo is actually only 7.4v and most servos(I think) run that voltage so actually the OP would need to find out the max volts the servo uses, if it were a 6v then I'd say use a bec just to play it safe because it can do 7.4v(others do it) but it can burn them out. But if you find out if the servo can handle 7.4 then just wire it directly
10-11-2011, 11:50 AM | #6 |
Whats a good cheapo BEC?
10-11-2011, 12:08 PM | #7 |
RCC Addict Join Date: Feb 2008 Location: Nevada
10-11-2011, 01:30 PM | #8 | |
10-11-2011, 01:38 PM | #9 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
This really depends on the servo he is running. Some servo specs allow 2s lipo voltage some are limited to 6 volts. I do not know the specs of the Axial servo so can'r speculate on that part.
10-11-2011, 01:44 PM | #10 |
Quarry Creeper Join Date: Jun 2010 Location: Marsing ID
get a castle creations BEC & a used castle link that way you can set it up to whatever voltage you want... |
10-12-2011, 08:19 AM | #11 |
Pebble Pounder Join Date: Sep 2011 Location: perth wa
+1 to airdreams1 best bec ever
10-12-2011, 08:30 AM | #12 |
Quarry Creeper Join Date: Oct 2004 Location: Somewhere in the middle
Yea BEC would definitely help! The link that prusik333 posted is the BEC you want |
