10-12-2011, 02:31 PM | #1 |
Quarry Creeper Join Date: Sep 2011 Location: ???
| Soldering Deans On Lipos
Anything I should Know before I Solder some deans plugs on to lipo? Never done it so just asking before I start. |
10-12-2011, 02:34 PM | #2 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
do one lead at a time completly, to help prevent the chance of a short. (if you are new to soldering or a rookie, choose something other then lipo's to practice on) I also find it handy to have the other end of a deans plugged into the plug your soldering, gives more to hang onto, and if by chance you start melting the plastic it'll help hold its shape. Last edited by fred0000; 10-12-2011 at 02:37 PM. |
10-12-2011, 02:37 PM | #3 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
x2^^^. Make sure you get the positive and negatives correct. Don't forget to put shrink on the wire first.
10-12-2011, 02:53 PM | #4 |
also dont cut both wires off at the same time for removing the old plug, cut one at a time the cutters will short the battery if you cut both at once, leaving the other wire attached to the old plug will be a good place for it while soldering the other wire onto the new plug. yes, dont foreget to put shrink tube on first, and if after a few attempts you have not succeeded put it down for a few and come back to it, gives the wires and plugs time to cool, they can become extremly hot very quickly. |
10-12-2011, 03:34 PM | #5 | |
Like was mentioned, if you've never soldered then practice on scraps. | |
10-12-2011, 04:06 PM | #6 |
I also like the plug a male into the female before soldering onto the female leads. This keeps all of the metal properly aligned in the plastic if you happen to heat up the plastic too much...
10-12-2011, 04:45 PM | #7 |
Quarry Creeper Join Date: May 2009 Location: pacific NW
Make sure you have a hot enough iron. I was trying to use a 25w iron at first, and was getting pissed, cause I thought I was stupid. I've got a 45w now, works great. Sent from my uber smart, smart phone.... |
10-12-2011, 05:35 PM | #8 |
RCC Addict Join Date: Jun 2008 Location: Amish Buggy PA
Tin the wire and the deans first then solder them together while drinking a few beers. It took me awhile to get good at this but moat wires in crawler lipos are small so they solder easily. Soldering the large wires on race lipos can be tough without a good iron.
10-12-2011, 05:45 PM | #9 |
RCC Addict Join Date: Aug 2005 Location: New Oxford PA
Another good tip, always heat the wire or tab first and apply solder while you are heating it. I've seen people melt the solder onto the iron and try to brush it onto the wires. Not good.
10-12-2011, 06:02 PM | #10 |
10-12-2011, 06:06 PM | #11 |
Quarry Creeper Join Date: Sep 2010 Location: Deus est mortuus, logica obtinet.
i always plug the female into a male as well. and make sure you have a good soldering iron, if not you will just get frustrated. getting a really nice iron is easily the best investment i've made in RC
10-12-2011, 06:10 PM | #12 | |
a high dollar soldering iron/station might help, but either way you're going to need to practice. good luck, IMO anyone in the RC hobby should do their own soldering, I think its sad to see hardcore RCers going to the hobbyshop to get their soldering done. | |
10-12-2011, 06:19 PM | #13 |
Soldering really isnt hard, it just takes a little while to get the hang of it. Like it has been said, tin the wire and the connector (or whatever else you will be soldering to...another wire, motor, esc, etc.) Then put the two things you are connecting next to one another. You will want something to hold them for you, they will get hot quick. A cheap set of helping hands is a great investment and has tons of uses if you start brazing also. Now touch both things with the iron (make sure you tip is also tinned for quick heat transfer) until you see the solder flow out and run together. If you can only get to one thats fine although it will take longer but it works the same way. If it looks like there isnt enough solder on your joint this would be the point to add some, shoot for the joint and not the tip of the iron when adding. Typically I tin the hell out of the two piece I want to join and I dont have to add any, it makes it easier and less complicated to do it this way. Remove the iron and let the joint cool and you are done...This stage is where I usually get burned, I seem to forget about the super hot rod in my hand and end up hitting myself with it in my excitement. |
10-12-2011, 06:54 PM | #14 |
soldering onto the female leads. .[/QUOTE] Like he said, solder the female plug to the battery. Male plug to the esc... very important.... Sent from my uber smart, smart phone.... |
10-12-2011, 09:48 PM | #15 |
Thanks for all the tips.
10-12-2011, 09:56 PM | #16 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
10-12-2011, 10:32 PM | #17 |
10-12-2011, 10:51 PM | #18 |
Quarry Creeper Join Date: Dec 2009 Location: jackson,tn
10-13-2011, 04:20 PM | #19 | |
Quarry Creeper Join Date: Oct 2011 Location: Detroit
10-13-2011, 05:00 PM | #20 |
RCC Addict Join Date: Nov 2010 Location: England
once i have cut the wires, i wrap a rubber band around the battery and tuck the wire im not soldering under the band. it stop the wire flapping around, getting in the way, and possibly shorting maybe get a couple of pieces of wire and practice first. most stuff said previously is good advice, that or plenty of video's on youtube |
