10-15-2011, 01:02 PM | #1 |
Quarry Creeper Join Date: Oct 2011 Location: Detroit
| Hitech 7950TH servo/CC BEC issue
Hi everyone. I have been milling around which Steering Servo to use in my XR10 build. I have narrowed it down to the one I'm most interested in at this time both for power and price. I'm interested in the Hitech HS-7950TH servo. I recently found that they rate this servo as being 486 oz/in with a speed of 0.13 when used at 7.4v. I will be using dual Tekin FX-R's and a Castle BEC. My question is: If I'm going to use a CC BEC, will I need to have it reprogrammed to output 7.4 volts (I believe they are factory set at 5.1v, not sure, but I know they are adjustable up to 9v I believe). Anyone that uses this servo/CC BEC combo care to give me some advice? I'd really appreciate any you could give! Thanks very much!
10-15-2011, 02:13 PM | #2 |
Quarry Creeper Join Date: Dec 2010 Location: gastonia
It works the same..I think... Just wire the power side of the BEC to the battery plug and the out put side to the servo. Keep the signal wire intact but out of the way it helps wonders when programming the BEC its self. Run the signal wire from you servo to the receiver. You do need a castle link if your using a castle BEC to program it to 7.4 try your LHS or try an locate one so you dont have to buy it to use it once.
10-15-2011, 03:32 PM | #3 |
Rock Crawler Join Date: Jan 2011 Location: New Brunswick
I'm running a Hitec 7950 at 7.4 volts in my XR and it works great. I setup mine using the Castle Link. It was really easy, but if you can borrow a friend's link, or use the hobby shop's Castle Link, it'd be better for you. The bec isn't something that you'll need to adjust often.
10-15-2011, 03:36 PM | #4 | |
10-15-2011, 04:00 PM | #5 |
Yep, try to find someone local to help raise the BEC output to match the servo. If you run Castle ESC's, it may be worth getting your own CClink to program all of it. Oh, with that much torque, you WILL find the next weak link in your steering....... |
10-15-2011, 04:15 PM | #6 |
| "Next weak link" eh? Do you care to share that info with me Charlie...or should I just be suprised? (hint: I don't like suprises like that )
10-15-2011, 04:20 PM | #7 |
| a side note
Just a side question to go with this thread. Since the CC BEC comes from factory with the output set at 5.1v, would it be ok to use with the 7950TH servo just like that? It would just give me less torque and slightly slower transit speed, right? Seems like it might be worth a try initially and that would give me room to ramp up the voltage/servo performance as I felt the situation demanded (without breaking steering parts right out of the gate?). Just curious. Thoughts?
10-15-2011, 04:28 PM | #8 | |
You have to see for yourself & your rig. It could be the tierod, knuckles, knuckle bearings, knuckle pivots, servo arm, servo mount, etc.............. | |
10-15-2011, 04:30 PM | #9 | |
