10-21-2011, 09:15 PM | #1 |
Rock Stacker Join Date: Mar 2011 Location: Manitowoc
| servo
Can u run a separate battery for the servo if u have a bec or no.
10-21-2011, 09:16 PM | #2 |
Why run a seperate battery if you have a bec?
10-21-2011, 09:23 PM | #3 |
because i want to get a servo that runs 7.4 lipo and i didnt know if the bec can put out that much
10-22-2011, 01:21 AM | #4 |
CC BEC, what most of us use (the 10A one).... Castle Creations | CC BEC and CC BEC Pro |
10-22-2011, 11:46 AM | #5 |
Thats the one I have I just didnt know if it could handle the servo or not
10-22-2011, 11:50 AM | #6 |
10-22-2011, 01:04 PM | #7 |
Newbie Join Date: Aug 2011 Location: Medicine Hat
It has to be set at 7.4v. It is 5v out of the box. You need castlelink to program your voltage. |
10-22-2011, 02:28 PM | #8 |
I thought the whole point of the newer "high voltage" servos was that you didn't need a BEC, you could just solder them straight to the ESC's power wires, saving you weight, and simplifying the system a little.
10-22-2011, 02:49 PM | #9 |
| Yes, you can. But your torque output changes as the pack voltage runs down. Most of the BEC's will maintain a constant voltage & amperage regardless of the input voltage (within reason).
10-22-2011, 03:10 PM | #10 |
Quarry Creeper Join Date: Dec 2008 Location: Lansdale
| The purpose for HV servos is to get more torque and/or speed. The purpose of a BEC is to ensure that your servo has power when your rig gets into a bind. |
10-22-2011, 04:31 PM | #11 |
10-24-2011, 09:59 PM | #12 |
The castle link is that the same one u use for the esc.
10-24-2011, 11:37 PM | #13 |
10-25-2011, 04:47 PM | #14 |
| On a 1/5th scale gas rc this is ideal...but in our world its for more torque and speed as already stated. You still want a bec, or you'll be loosing like 30% of your torque and speed. between full charge and low voltage cut off
10-25-2011, 06:25 PM | #15 |
10-26-2011, 03:27 PM | #16 |
I've never had an issue running my servos straight of the battery. If you set your BEC to 7.4 volts, then even with a fully peaked 2s lipo your running less voltage than straight of the battery. And once the battery gets below 7.4 volts the BEC can't increase the voltage back up. So I don't see the advantage to running a BEC as long as you exclusively run 2s packs. I guess my lipos dump so fast I can't really tell that the steering is loosing power because the LVC in the ESC cuts out first. |
10-26-2011, 04:15 PM | #17 | |
10-26-2011, 05:15 PM | #18 |
