10-23-2011, 02:09 PM | #1 |
Quarry Creeper Join Date: May 2011 Location: El Paso TX
| disrutor tranny, what motor is best
im going to be running a disruptor tranny and killer t-case and was wondering what would be the best motor to run i have a hh pro handwound 35t and was going to try that but dont want to burn up the motor. i also have a hh 10t puller but like i said im just not to familliar with this set up so would like some advise thanks |
10-23-2011, 02:50 PM | #2 |
1-What rig is this in? 2-Is this a "for fun" rig or do you comp? 3-If you comp, what class do you run in? I highly doubt you will burn up a HH (or Br00d) motor, unless you waaaaaaaay over gear it. |
10-23-2011, 05:11 PM | #3 | |
its going into an x-trail with t-rex 60s fxr esc on 3s with 1.9 baja claws class 2 hopefully thanks for the help i have never run this tranny and from what i have read i know its 16:1 gearing so i figure NO WHEEL SPEED but i just dont know. no one i know runs this set up so any info would be greatly appriciated thanks in advance | |
10-25-2011, 07:19 PM | #4 |
Any help please
11-24-2011, 11:30 PM | #5 |
Pebble Pounder Join Date: Jan 2011 Location: Red Hill, Pa
Sorry I didn't see this thread earlier. I've been using the Disruptor (compact) tranny/gru and t.case for some time in a 9.5 lb + scaler with Axial axles (used all gear ratios - stock, od/od, od/ud, ud/ud). I've used brushed motors on 2cell lipo from 70t lathe down to a 30t Brood. This drivetrain is simple, tough as nails, and good looking. And unstopably torquey. And SLOW as SHIT! You'll never win a hillclimb. Your Mudslingers won't sling any mud. But you'll have an unstoppable tank, with some well-placed weight. The 30t was the fastest yet (obviously) but still laughably slow. Slowest scaler in my club, hands down. I tried the "od" Disruptor t.case and it sucked balls. It WAS about 3 times faster on flat ground, but with the 70t motor it couldn't climb up onto a red brick. Pathetic. For a heavy rig that doesn't need any real wheelspeed, I like it. If you wanna run with the Honchos, this tranny is NOT for you. |
