10-24-2011, 12:06 PM | #1 |
Rock Crawler Join Date: Jan 2008 Location: Lincoln
| 14 turn cobalt....
I have a BRXL/14 turn puller combo coming in today from HH, and to be honest, my head's spinning between all the specs on 7 and 10 turn pullers, not much on the 14turn. never run a puller, haven't a clue where to start on gearing or how to even set the timing. Here's my situation: I've been running Parkers' G6's for about a year. These can be tough on an RC in allot of new and different ways... It's a rally event where you run on average 300 trailmarkers over the course of the day, one course can be up to 200 T/M, and could be an hour or more of constant running over all kinds of crazy terrain. (rocks, mud, water, etc,etc,etc.) I run a heavy rig (10+ lbs) and when the foams are wet it's even heavier. I was running a 3cell Goat with 18turn brushless, replaced two timing rings in it before it finally went up in a mushroom cloud a few months ago. Then I ran a 23 turn handwound (from JPH) which was great until I shorted out a wind and that blew up on another G6. Since then I've gone through about 4 motors. My gearing hasn't been anything crazy, 14pinion, stock spur(87?) Finally, I got around to this combo. I'm hoping it will do the trick. I chose the 14 'cause I'm hoping it will keep the temps low while providing a lot of giddy-up, with respectable run-times. Anyway, the point to this babble-fest is where do I start with the gearing? Do I have to advance the timing 6degree's out of the box? Anybody else running the 14turn? How does it do on 3 cell? Or 4 cell? |
10-24-2011, 02:20 PM | #2 |
interested in seeing what info you get on these, I'm considering using a puller in my Willys, I'm sick of smoking my handwound 35T's.
10-24-2011, 02:39 PM | #3 |
I have one. In regards to the timing, I'm thinking John has it set somewhere safe, but it's always a good idea to double check or set it yourself. Run it for a second forward and reverse full speed and listen for forward running faster. If it doesn't loosen the two screws on the endbell, and rotate the the thing about an 1/8 of an inch counterclockwise looking down on it. Tighten up the screws and do the forward and reverse thing again and listen for a faster forward. Keep going until you get a slightly faster forward. Might as well start with the same gearing and see how you like it, though it'll probably be a little slow, until you up the voltage. The BRXL and that motor take a liking to 6S lipo. I ran that in a truck a while ago and loved it. If you stick with a 3 or 4 cell lipo, keep going up pinion gears while checking for excess heat in the motor. There's probably enough grunt in that motor to be able to handle a rather large pinion gear. |
10-24-2011, 05:27 PM | #4 | |
Got my package today, and this thing is really interesting, the can is longer, but with a smaller diameter. The comm is huge! Motor's cool but there is something a little out of whack: there is no flat spot ground on the shaft for a pinion. (?) Plus the mount is tapped for 4-40 instead of 3mm (??) | |
10-24-2011, 05:43 PM | #5 | |
4-40 it is, and that's just the way it is. At least you got some screws with it. | |
10-24-2011, 05:58 PM | #6 | |
10-25-2011, 12:20 PM | #7 |
10-25-2011, 12:32 PM | #8 |
Good info for sure. I don't really have much to add, except if you have a temp gauge it is best to keep the can under 180f. The magnets will take 300f, but I recommend 160f on the can just so the motor lasts a really long time. You should have a lot longer service life and lower operating temps with the puller. It is about time I get the Puller 2 done so we can continue having such awesome motors when my supply runs out. |
10-25-2011, 02:36 PM | #9 | |
I'm just kinda taking my time with this, I'm also new to the BRXL, and using a castle link. (Historically I'm a Novak guy) I have a feeling running big voltage can get pretty addicting. I have good feelings about this combo. Anyway, picked up some air filter foams to cover the endbell and filter out the crud. I'll wash them to get a majority of the oil out of there. Last edited by brokennib; 10-25-2011 at 02:42 PM. | |
10-25-2011, 02:37 PM | #10 |
10-26-2011, 01:51 PM | #11 |
After switching around some wiring and making a simple radio tweek, I made a successful run around the yard. Timing was set up perfectly. I threw a 18t pinion on the motor as a starting point- not a whole lotta top speed, (on 3cell) but the torque is AWESOME ! Wow! Torque is one of those things I don't usually miss until it's gone, like the last three cheap stock motors. Very cool. I'll do more proper testing this weekend, I'm waiting on a few parts. I have a 4cell on the way and a set of felsonfest spools to help beef up the drivetrain, I definatley want those in before I order a 6cell In the meantime I can get more familiar with the Castle Link software. I'm also really happy at how it cleaned up all the wiring on the truck-having the onboard bec is real handy. Anyway, I'm just digg'in the hell out of this combo. Thanks guys for the all the help ! |
10-30-2011, 08:43 AM | #12 |
Just a itty-bitty update..... Welp, after many calculations. (really just punching numbers into a setup calculator) and a lot of guess-timating, I came up with some gearing numbers that were a start. Anyway, the combo ran great yesterday 40+ minutes of solid, somewhat demanding runtime. Highest temp (with 4cell) was 117 degrees. Not bad That's a final drive ratio of 10:53, I might little lower to see how that goes. I'm just jazzed as hell about this combo, really worth the investment. |
10-30-2011, 12:25 PM | #13 |
10-30-2011, 12:33 PM | #14 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
The puller motor are awesome for their control and power. i love mine for sure. To figure out your final drive you need to figure your axles into the equation also. You should be in the 25:1 - 35:1 area in most cases running the axial tranny.
10-30-2011, 07:55 PM | #15 | |
If you squint hard enough, it almost looks as though I know what I'm doing. | |
