10-26-2011, 11:33 AM | #1 |
Rock Crawler Join Date: Aug 2011 Location: tri cities
| truck shuts down?
I have a ae-2 esc, castle bec, ae-3 rx and tx on 3s with a 45t integy v12. The problem I'm having is the truck will be running and then no more throttle. The esc is beeping like it no longer has radio signal. I shut it all down and unplug the battery and about 75% of the time ill turn it all back on and it works but, the other 25% I have to keep messing with it. Does anyone else have this problem or a suggestion on what's goin on?
10-26-2011, 11:48 AM | #2 |
Does it happen with different batteries? Does it happen after running a while (heat in the ESC, failing battery packs)? What ESC lights do you see when this happens? Does the steering die as well? Does it only do it in a bind? Is either the ESC or motor hot when it happens? Does any of it match the bottom of this document.... Castle Creations | FAQ: 1/10th Scale Products ?? |
10-26-2011, 12:33 PM | #3 | |
10-26-2011, 02:42 PM | #4 |
Yep, sounds like a RX issue. Double check all the connections (power, servo's, antenna, etc). It may even be inside the RX case.
10-26-2011, 03:36 PM | #5 |
Well atleast its a cheap fix. I have another tx and rx I'm going to try when I get off work and see if that does the trick. Its not an esc problem, not a motor problem, not a battery problem and not a bec problem so it looks to be the rx is the only thing left. Thanks for your help. Axial uses flysky products right? |
10-26-2011, 05:06 PM | #6 |
No problem on the help, there is nothing wrong with a sanity check. Let us know what happens when you run the other radio. Don't forget to calibrate the ESC to the radio. |
10-26-2011, 06:39 PM | #7 |
| Lol well I got another question. I've never set a ae-2 esc to a radio before. Do you got any tips on that or do I need to get on good ol google?
10-26-2011, 07:54 PM | #8 |
Google up the ESC manual. They are all similar, but not identical.
10-26-2011, 08:54 PM | #9 |
How is the BEC hooked up? Is the BEC and ESC both powering the rx?
10-27-2011, 11:59 AM | #10 |
| No the red wire is cut on the esc, its just the bec that is powering the rx. I was thinking it could be the bec took a dump but, the green light is still on then the rx shuts down. I guess it could be a bad wire from the bec to the rx??
10-27-2011, 05:41 PM | #11 |
Could be a bad wire between the ESC and rx, I've got a KO rx that just decides not to power up every now and then. I'd finish a course and then when I powered up for the next one ten minutes later nothing.
10-27-2011, 07:22 PM | #12 |
| Yea it'll do that too but sometimes ill just be cruisen and it'll shut down.
