10-26-2011, 07:16 PM | #1 |
Rock Stacker Join Date: Jan 2011 Location: Sun Valley
| Dual 35s batteries |
10-26-2011, 07:23 PM | #2 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
If your looking to dbl capacity at same voltage you want a parallel conection. Basically both +'s together and both -'s together. it looks like thats what you have from what i can see. |
10-26-2011, 07:32 PM | #3 |
yea thats how i have it i just want to make sure im doin it right
10-26-2011, 07:35 PM | #4 | |
The above is a way to ~double capacity. The ESC should be fine with that. A series connection (- of one pack to + of the other pack) will ~double the pack voltage but maintain the capacity which may also fry the ESC. | |
10-26-2011, 07:42 PM | #5 |
the more i like at the - to + is ho it is set up. im assuming i should change that.
10-26-2011, 09:07 PM | #6 |
Yes that would put you a dbl voltage, same capacity. So if you have 2s packs that would give you 4s power w same capacity. If your esc is rated to 4s enjoy the extra speed, if not you might see the magic smoke... |
