Thread: Radio
Old 10-30-2011, 09:40 AM   #1
Default Radio
I just bought a 3 ch radio for my trucks but turns out I wanna use more things then intended so now I would like to know whats a good 4 or 5ch radio thats good and has at least 15 truck memory any help would be nice
6wheelking is offline   Reply With Quote
Old 10-30-2011, 11:02 AM   #2
search gt3b....or even 4 or 5 channel radios and start reading the tons of info on here
squatch71 is offline   Reply With Quote
Old 10-30-2011, 01:26 PM   #3
LosiKids hacked GT3b or a Futaba 4PL.....
Charlie-III is offline   Reply With Quote
Old 10-31-2011, 12:12 PM   #4
Will a RC airplane/helicopter radio work with the trucks?
Old 10-31-2011, 12:41 PM   #5
Ummmm....yes.....BUT, there are ground/surface radios & airborne radios. Usually the TX & RX are specific.
With 2.4ghz, there is not as much issue, but with the older AM & FM radios you really should stick to the correct application.
Old 10-31-2011, 12:59 PM   #6
Futaba 7C 2.4ghz Fasst computerized RC helicopter radio with 4 servos
Spectrum DX6i 6-Channel 10 Model DSM2 Airplane Heli 2.4ghz Radio
will these to radios work with trucks
Old 10-31-2011, 01:34 PM   #7
The radio does not care what you use them in, the FCC does though.
A speed control is a speed control.....a servo is a servo......no matter if they are ground bound or airborne.
Usually you CAN'T mix surface & airborne radio bits, thus if you have an airborne TX you HAVE to buy airborne RX's.
Old 10-31-2011, 02:56 PM   #8
I've always wondered this...whens the last time the FCC walked up to a bunch of guys with radios and RC cars and asked to see the radios and see if they are ground or not. Have always wondered if they even know what to look for.
Old 10-31-2011, 03:11 PM   #9
They don't patrol but if there is a complaint filed they will follow up and investigate. Usually it's not a problem but the bigger issue was with AM or FM bands, if you were within a couple miles of a model flying field you could possibly "shoot" down an aircraft and cause some damage people or property in that area.
I had plenty of experiences with the FCC as the compliance officer for radio communications on the public safety band. (For transit and emergency comms). They can be pretty tough if they are on your case.
AreCee is offline   Reply With Quote
Old 10-31-2011, 08:38 PM   #10
Thanks very helpful I understand how it all works now
