Thread: 2 Cell Li-Po 7.4v 1800mAh
Old 11-01-2011, 09:16 AM   #1
Default 2 Cell Li-Po 7.4v 1800mAh
Hi Guy's...
Sorry if this has been asked before...
Just got 2 Li-Po's today in the Post...
Never used 2 cell before ( only 3cell on my R/C Gliders )
They both arrived with 7.8 volts and 3.90v in each cell...
Got them on a balance charge now,before I use them...
Still waiting on a Li-Po low Voltage alarm...
But untill that arrives .. what is the safety point ( lowest voltage)
I can run them too... ESC does not have a cut off...
Thanks
Sean...
West Cork Basher is offline   Reply With Quote
Old 11-01-2011, 10:03 AM   #2
the absolute lowest safe voltage is 3.0v per cell, but i wouldnt run lower than about 6.5v for a 2cell pack. you should notice a drop in performance and at that time you should quit w/o a cut off
benoj is offline   Reply With Quote
Old 11-01-2011, 11:36 AM   #3
Thanks...
I just wasn't to sure about the lowest voltage...
Sean...
Old 11-01-2011, 12:06 PM   #4
when your esc does come..I program mine to 3.1 or 3.2V per cell.....just incase.
squatch71 is offline   Reply With Quote
Old 11-01-2011, 01:15 PM   #5
Using a Viper ECO 20 thats why I'm getting a
Li-Po Low Voltage Alarm, you plug it into the balance plug on your Li-Po
Old 11-01-2011, 06:38 PM   #6
im not fimilar with that one, is it adjustable? most of them come set to cutoff at 3.0v per cell or 6v. the ones that go by each cell are better incase the cells are slightly out of balance so one is above 3 but the other may be below 3 and could end up damaged if it goes to low
Old 11-01-2011, 06:49 PM   #7
It's not a Crawler ESC as such,but it's a good ESC as it water proof...
Eco20 has a 20 turn motor limit and has forward, Brake and Reverse
Sean...
Old 11-01-2011, 07:58 PM   #8
Agree with benoj, if your cells aren't ballanced you could take one down past 3V per cell...typicaly, thats bad
this might be a good esc for rcs like it says, but for crawling...prob not, bec of 1.2A, no drag brake..with a BEC it might be great for rally racing. I wouldn't toss it. When funds allow, I would upgrade...keep this one, does seem like a decent back up.
Old 11-02-2011, 02:03 AM   #9
Yeah...
I'll have to buy a ESC for use with Li-Po's, but can still be used with a low turn motor...
Old 11-02-2011, 06:42 AM   #10
Originally Posted by West Cork Basher View Post
Yeah...
Well I've just POPPED my ESC ...
Doesn't look like it could handle Li-Po's.....
Sean.
Old 11-02-2011, 07:27 AM   #11
Sean.
ESC doesn't care the chemisty of the battery, it only cares the voltage.
Charlie-III is offline   Reply With Quote
