11-04-2011, 09:23 PM | #1 |
Pebble Pounder Join Date: Aug 2011 Location: omaha
| Help! Fxr on/off switch wires
So I attempted to remove the on/off switches from my fxr's. The first one went fine, while I was trying to do the second one and I had a little pressure on the wires coming out of the circuit board, got em a little too hot and out they came... So now I have no wires connected to the board and two empty little holes. Thinking I might be able to get a small glob of solder over the two holes? Am I screwed? Any advice would be very much appreciated -Matt |
11-05-2011, 07:54 AM | #2 |
You can either get a solder bridge across the 2 holes, or (better) would be to drop a small piece of wire into the holes and solder it in. You could cut a length of the wire from the switch to use. |
11-05-2011, 09:47 AM | #3 |
Thank you! I'll give it a try and see how it goes.
11-05-2011, 10:25 AM | #4 |
My speed controls live! Thank you again!
11-05-2011, 10:48 AM | #5 |
