11-06-2011, 01:57 PM | #1 |
Quarry Creeper Join Date: Oct 2011 Location: Westport Island
| Axial Wraith speed control issue
Howdy, my new wraith with about 4 batteries through it has started to act up. If you gently apply throttle until wide open, all is well. If you smash the throttle wide open it lurches and does nothing until you release the throttle slighty and then it will take off, you can then apply full throttle. I have "re-bound" the radio, and the speed control light goes to full red under both scenarios. Any ideas? Thanks. |
11-06-2011, 05:23 PM | #2 |
Did the LiPO cutoff (AKA, LVC) get set/reset? Does it do it on one battery pack or all packs? What batteries (# cells, mah/capacity, "C" rating)? |
11-06-2011, 06:01 PM | #3 |
Its a six cell NI-MH 3300mah, and yes it does it on both of the packs I have for it.
11-06-2011, 06:07 PM | #4 |
| Ahhhh....sounds like the ESC has the LVC enabled, it is likely shutting down the ESC under load (thinking you are running a LiPO pack). Check the ESC and turn the LVC off if you find it enabled. |
11-07-2011, 12:57 PM | #5 |
Quarry Creeper Join Date: Aug 2011 Location: not south enough
| Issues too
I am having issues with my stock Wraith ESC too, I wonder if this is my issue too, if so how did you reset the esc to standard mode or turned off the LVC? Mine just blinks red and green at the same time and does nothing when I plug it in and follow setup?
11-07-2011, 12:59 PM | #6 |
Quarry Creeper Join Date: Oct 2011 Location: Georgetown, On
yep thats the low voltage cut off for the esc. try it with a fully charged battery pack and tell us if its doing the same thing. Not sure on reset, as i bought my wraith in kit form with no stock ESC |
11-08-2011, 03:09 AM | #7 |
Hmm...sounds like were getting handle on this. It turns out its a Castle esc and in order to make adjustments I think I need a "Castle link" usb thingy. The odd part is it didnt act up at first, and has slowly become more consistent. Thanks for the help guys! |
11-08-2011, 05:35 AM | #8 |
| Yes, you need a Castle Link. The good part is that the same link will also work with Castle BEC's. |
11-11-2011, 12:31 PM | #9 |
Hey guys, just back from my LHS with my Wraith that had an esc issue. He turned off the "lipo cutoff" and the issue still existed. We called Axial, got right through, and the gentleman asked what I had for batteries and said that the Nm Hi didnt have enough "poop" to satisfy the esc, and to try a lipo. My guy pulled a new 2cell from the package, plugged it in and all was well!!! now my Wraith is back in business!! |
11-11-2011, 12:40 PM | #10 | |
Maybe you have a NiMH cell starting to fail (within the pack), that would cause issues as described. | |
11-11-2011, 05:33 PM | #11 |
| Its a 3300mah speedpack dy Dynamite, I bought two of them in may of this year and they each have only 10-12 runs on each, with the new lipo the wraith goes REALLY well!! very pleased!
