Thread: Cc bec
Old 11-14-2011, 04:24 PM   #1
Default Cc bec
Hey Guys,
A have a new CC BEC and I am wondering which Port I should plug the cord into on my Spektrum AR600. E.G. BIND/DATA port or Landing Gear port or Auxillery port e.t.c
Thanks,
Jayden
rockpanda is offline   Reply With Quote
Old 11-14-2011, 04:36 PM   #2
Any port will work.
JeremyH is offline   Reply With Quote
Old 11-14-2011, 04:39 PM   #3
Originally Posted by JeremyH View Post
Any port will work.
+1.
I actually prefer to wire the BEC direct to the servo.
Charlie-III is offline   Reply With Quote
Old 11-26-2011, 02:32 PM   #4
Default plug Bec
Hi guys, I'm just about to plug my AR600 spektrum, with a castle creation on the AUX channel of the AR600.
I have just red that you dont recommand it ?
Can you tell me why ?
My setup is:
XR10 4WS
reciever ar600 spektrum
Channel Thro = Front esc (tekin FXR)
Channel Aile = Rear ESC (tekin FXR)
Channel Elev = Rear servo steering (hitec HS 7954 SH)
Channel Rudd = Front servo steering (hitec 7954 SH)
Channel Aux1 = CC bec castle creation
Thanks
rc777 is offline   Reply With Quote
Old 11-26-2011, 03:01 PM   #5
My setup is:
XR10 4WS
Thanks
If you run an external BEC through the RX with the ESC, the 2 BEC's (external as well as from the ESC) will fight, smoke usually happens next.
If you want to run the external BEC through the RX, remove the red wire that goes from the ESC to the RX (DON'T cut it off, just remove it from the RX connector and tape it up) and let the external BEC power everything.
Old 11-27-2011, 03:12 AM   #6
Default BEC with AR600
Yes I did, sorry man I forgot to mantion it. But I have cut the wire. Well I suppose that I can still weld it back and remove it from the connector
My question is : Is it ok to power my AR600 with the castle BEC thought the AUX1 channel ???
Here is a picture. of my mounting.
Uploaded with ImageShack.us
Old 11-27-2011, 03:16 AM   #7
You can power it thru any port
AlexG is offline   Reply With Quote
Old 11-27-2011, 03:18 AM   #8
Ok great at least will have no smoke when I will plug my lipo
But Why some guys dont recommand to power the rx throught the BEC ????direct to the servos and power the RX throught the ESC ???
Thanks Mate....
Old 11-27-2011, 08:32 AM   #9
OK great, at least will have no smoke when I will plug my LiPO
But why do some guys don't recommend to power the RX through the BEC ???? direct to the servos and power the RX through the ESC ???
Thanks Mate....
Since the ESC already is there & working, I let the internal BEC handle the light load items. Then, all the power output of the external BEC just drives the servo.
Some radios (mostly Spektrum) really want the black wire from the external BEC to go to the RX to stop glitching. Futaba's seem to do fine without that change.
I also have had a few CC BEC's die by going to full battery power, I'm not sure the RX would be happy getting 3S LiPO power direct into it.
And yes, you can run the BEC output to any open RX port if that is the method you chose.
Old 11-27-2011, 08:59 AM   #10
Thank very much charlie III for those infos
