11-16-2011, 10:25 PM | #1 |
Newbie Join Date: Aug 2011 Location: Guam
| velineon giving up
i was wondering is it normal for the velineon motor to give up on mild climbing. ill be trying to climb, the rig will start shacking and then just rolls back. I know the motor sucks on rock crawling but is this normal?
11-17-2011, 12:20 AM | #2 |
Rock Stacker Join Date: Jun 2011 Location: B.C. canada
I had the same luck with mine, the esc would go into thermal shutdown when I tried to crawl with it. I had it in my wraith geared 80t spur, with 16t pinion. I chucked it, went back to a 35t brushed on 3s and haven't looked back. I wish you better luck with yours. Cheers.
11-17-2011, 02:43 AM | #3 |
Was yours a brief moment or did the esc shut down completely and had to turn it on again?
11-17-2011, 01:37 PM | #4 |
Rock Crawler Join Date: Dec 2009 Location: Beaumont, Tx
make sure your battery plugs are good. I have had them shut down on jumps in the SC trucks because the battery connector was loose.
11-17-2011, 03:59 PM | #5 |
What rig? What motor? What battery (type & # of cells, "C" rating if LiPO & capacity)? Is the ESC or motor getting hot when it does this? What battery connectors? What servo? Do you run an external BEC? |
11-17-2011, 04:07 PM | #6 |
I've got 2 VXL systems. The older one, pre waterproof, is a dog... it needs rebuilding or something. It used to run good but it's getting slower... the 2nd (waterproof) really performs. I had it in my Summit trans SCX10 and it could climb, pull the sled and kicked butt in the mud pit during a few TTC's... basically it did everything I asked of it. No drag brake sucks though. Here's a video of it in the SCX on wet rocks. |
11-17-2011, 04:47 PM | #7 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
| Really sounds like cogging from a non-sensored motor. You could try a sensoered motor with the velenion esc, but a Mamba Max Pro or Tekin rs. Is a much better esc.
11-17-2011, 05:24 PM | #8 |
my dog got to the esc and ripped up the wires to the motor so i did a quick fix on it. could that be the problem? i was reading about the thermal shut down but my esc doesnt shut down, the motor stops rolls down the hill and ill try again
11-17-2011, 05:27 PM | #9 | |
venom 5000mah 2s 30c deans hitec 7954 and no external bec | |
11-17-2011, 05:57 PM | #10 | |
DOes it happen on other packs? Does the motor or ESC get warm/hot? Does the steering quit when the motor quits? Still wondering if you're browning out the RX. | |
11-17-2011, 06:05 PM | #11 |
The servo is kinda amp hungry to run off aa velenion. For an experiement, try no touch the steering wheel and see if does it. The shaking still sounds like cogging to me. Are these mild climbs at slow speed and little throttle input? |
11-17-2011, 06:05 PM | #12 |
yes it happenes on there packs the motor and esc gets hot even with the fan on the esc and no the servo doesnt quit |
11-17-2011, 06:08 PM | #13 | |
ill be hammering it down to get up, cogs, then hammers down again, then just stops. ill let it roll down a little then try to climb again | |
11-17-2011, 06:11 PM | #14 |
Maybe double check the wire and connections. Making sure all is tight and no bare wires can touch each other. Maybe tug on the wires with it running in the air.
11-17-2011, 10:04 PM | #15 |
I think it's the motor... sounds like my first one. Seriously, the vxl should tear up hills. If it's dying mid climb w/full throttle... it's gotta be the motor or batteries. btw, I was running a 270oz servo straight from mine w/no issues.
11-18-2011, 05:57 PM | #16 |
It finally gave up on me. So now I got a new velineon system and it works good on 2s but On 3s it will be fine then no throttle then after a min or two it would start working again
11-18-2011, 05:59 PM | #17 |
It's a brand new VXL ESC and Motor and it's not working? Did you by chance solder your own battery plugs? Maybe the 3s has a short. |
11-18-2011, 06:06 PM | #18 |
Yes it's brand new. And the battery is brand new too.no I didn't chagr any plugs. I'll switch the batteries to 2s and it's fine. But on 3s it will work fine then no throttle. Then it will start moving again
11-18-2011, 06:08 PM | #19 |
Did you set the esc to lipo mode?
11-18-2011, 06:31 PM | #20 |
Sounds like it's overheating and doing a thermal shutdown. Running 3S and no BEC with a 7954 will likely do that, get a CC 10A BEC and run it direct to the servo. |
