Thread: Lipo discharge, or...
Old 11-18-2011, 05:40 PM   #1
Default Lipo discharge, or...
Ok, not sure I am totally following with the discharge of the lipo's.
Charger/ discharger: TritonEQ
Batteries: 1300 mah/ 11.1v/ 3s
So if I discharge it does it @ 1v rate and takes the battery down to 9v. Does that sound right for the battery I am running?
If I run my batteries down in my crawler then only charge to 9v would that be accomplishing the same thing for long term storage?
I did a search but not finding exactly what I am asking. Any positive input to answer my questions are appreciated.
snydercj7 is offline   Reply With Quote
Old 11-18-2011, 08:37 PM   #2
9V is dead dead deadski for the 11.1V lipo. The charger is discharging to the lower limit. Storage should be around 11.7V I believe. Fully charged should be 12.6V.
Coops is offline   Reply With Quote
Old 11-19-2011, 07:33 AM   #3
+1, that is a "Wee Bit" too low.
These are LiPO's, don't treat them like NiCD's.
Charlie-III is offline   Reply With Quote
Old 11-19-2011, 08:12 AM   #4
Proverbial threadkiller
Trubble's Avatar
+1 on what Coops said, storage voltage should be as close to 11.55 as you care to get, or 3.85v per cell. 11.7 would be right about on the money.
+1 on what Charlie said, too. Pretty sure I lost a LiPo last night (being stupid). On a sidenote; if your ESC has a cutoff, use it. A lot of cutoffs are set at a factory default of 3.0v per cell, about as low as you'd wanna go. On my MMM, I run mine at 3.4v per cell just to be cautious. Or, if your LiPo has a balance port, get an alarm. I had no idea I was wrecking my battery, because mine has no balance plug, so I had no alarm, and there was zero indication in performance that I was riding into the danger zone.
Trubble is offline   Reply With Quote
Old 11-19-2011, 08:28 AM   #5
If you want to "store" lipos, just run them in a vehicle until the resting voltage is about 3.7 volts per cell. Done.
Manning is offline   Reply With Quote
Old 11-19-2011, 12:11 PM   #6
Thanks for the input guys. Feel like an idiot, because I am still not really grasping how the discharge on the charger works.
I do have the esc cut off programmed. That sounds like the way to do it.
I did run a discharge @ the 9v with the balancer plug. When I put the battery on the charger it shows each cell @ 3.56. Hopefully it saved me from my stupidity. After this batter finishes charging I will see if I can set it to discharge to 11.7v.
Old 11-19-2011, 12:22 PM   #7
Discharge is one thing, storage charge is another.
Old 11-19-2011, 12:30 PM   #8
Thanks bud... Now I am really lost, or maybe I was just using the wrong terminology. I was actually asking about storage.
Old 11-19-2011, 03:30 PM   #9
Discharge usually drops the voltage to a minimum "safe" voltage for whatever battery chemistry you put in (NiCD, NiMH, LiPO, etc) along with some adjusting.
A "storage charge" is usually about 1/2 of the allowable range for a battery chemistry (AKA, 50% charge).
Make more sense now? If not, ask.
Old 11-19-2011, 06:18 PM   #10
So I have an SMC Sport Max 2s 2200mah and I run it in my Mini revo vxl until the truck pretty much stops (gets all jittery) I pull it and test voltage with a multi and get 6.98....am I killing my lipo by running it so low?
I have a balance plug but no alarm at this time.
Also Is this battery safe to use in my LNC? The book says the ESC can do a 2s, but is there anything I should do before using this in that rig? Ive been running nicd until now.
Not sure if I have a BEC but the motor came with a big BEC looking unit on both + and - sides.
I may be limited to 2s, but is there a max mah I should stay below?
Thanks for the help
-BIGMAXX- is offline   Reply With Quote
Old 11-19-2011, 08:18 PM   #11
-You can run any mah that you can fit in the rig.
-When you check the voltage, it has rebounded with the load off, thus the actual voltage when things get jittery is lower. I would quit as soon as you see a loss of power/control.
-You can use any battery chemistry in any rig, it helps if the ESC has a low voltage cutoff (LVC) so you don't overdischarge your LiPO's (if you run them). The only thing the ESC cares about is the voltage & polarity.
-Those "big BEC looking things" on the motor are likely caps that filter out spikes & electrical noise from feeding back into the ESC or RX.
Old 11-19-2011, 08:44 PM   #12
Thank You, you are a wise and all knowing Charlie
Got my first lipo only a month or so ago and was unable to use it till I got a charger for it so this is all new to me.
Old 11-19-2011, 09:50 PM   #13
Glad to help.
Even better is when I give good & correct answers!
Post back if you have more questions or issues.
Old 11-19-2011, 10:23 PM   #14
as long as OP doesn't mind I could use a real good explanation of what exactly a BEC is and what it does, along with whats gonna happen since I don't have one. I know I should know this but I don't
