11-19-2011, 07:06 PM | #1 |
Newbie Join Date: Jan 2011 Location: Northport
| Steering servo cutting out!
I have a new hi-tec 7950th steering servo with a castle bec connected to it. both are brand new. And it is cutting out off and on! Anybody have any ideas? Its on an Axial Wraith Thanks |
11-19-2011, 08:12 PM | #2 |
1-What voltage is the BEC set for? (stock is 5 volts) 2-Are your servo end points set so you're not binding the linkage? 3-Does the throttle still work when the servo quits? |
11-19-2011, 08:19 PM | #3 |
1. 7.1 2. have not checked that out 3. yes I think I may have found the problem. I beleive the bec does not have a good connection. I am going to cut the heat shrink and check the connection. I appreciate the response and reminding me to set the end points. Thanks! |
11-19-2011, 08:37 PM | #4 |
No problem, come back if you have more questions. |
11-19-2011, 08:41 PM | #5 |
RCC Addict Join Date: Jun 2008 Location: Amish Buggy PA
| I have had several Castle becs' come unsoldered for me so its a likely solution to your issue.
