11-22-2011, 02:57 PM | #1 |
Rock Crawler Join Date: Nov 2009 Location: bolivar mo
| My motor is acting like a starter not wanting to crank over?
Seriously I dont even klnow how to search this but heres my quesion. Set up is a HH br-xl and 7t puller low speed crawling it makes the ordinary noises but it acts like its a starter in a 1:1 on a low battery. Ill post a vid Weird noise? - YouTube . Its not smooth at all on the bottom end either. Watch and hear the rythm of the motor? thanks |
11-22-2011, 03:26 PM | #2 |
11-22-2011, 03:50 PM | #3 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
Yup sounds like spur gear wobble to me as well, plus the twist the truck is getting makes me thing the gear mesh it too tight.
11-22-2011, 05:37 PM | #4 |
Yea I agree, rotate the spur by hand and I bet there is a tight spot. Once you find it set your mesh at the tight spot and then everything will be good.
11-22-2011, 05:59 PM | #5 |
Thanks you all for the fast answers. I assume a new spur? Also the mesh I thought was fine il double check! |
11-22-2011, 09:07 PM | #6 | |
Cheap brands/bad batches are worse, thus they have tight spots as they are rotated. As mentioned, spin your spur gear a full 360* and see if there is a tight spot in the gear mesh. | |
11-23-2011, 06:23 PM | #7 |
I can't find a tight spot. I've been trouble shooting this all day. I'm gonna pull my lil girls 55t off her rig tonight just to hopefully rule out my puller. Hell may be bad dirty or baring bad or something? Wouldn't think so but maybe. I haven't ran it in a few months. This is a badass combo I just want it back to normal.
11-23-2011, 09:21 PM | #8 | |
11-23-2011, 10:06 PM | #9 |
Well I think I figured it out. My wheel base is 12.5" and I was using a wraith tranny. I think it was puttin a bind on the MIPS. Put ax10 tranny in and it's fine I think now. It's not as smooth on the bottom though. Now I just need to tweek. |
11-23-2011, 11:14 PM | #10 |
Newbie Join Date: Nov 2011 Location: england uk
| noise
the high pitch is fine , but the movement looks like its binding or somethings bent along the transmission drivetrain
11-23-2011, 11:32 PM | #11 |
