11-24-2011, 11:50 PM | #1 |
Pebble Pounder Join Date: Jun 2009 Location: Santa Cruz Mountains
| Did I just Fry Everthing? Ahhh
I was up late last night getting my Berg all wired up. Spent tons of time cutting the wires to the correct length, laying down some perfect solders, making everything removable using bullet connectors. Then what do I do, wire the deans connector wrong coming off the ESC to Batt. Plug it in, and I hear a PUFF and the battery got so hot I had to drop it. : ( As far as I can tell the FX-R is fried, I hope the Punk dig is ok, as well as the motors. Everything was brand new. I was so bummed I just went to bed. Next time I won't stay up till 2am working on technical stuff. Will Tekin be able to fix the ESC? or is it toast. |
11-25-2011, 12:39 AM | #2 |
Yea your FXR is fried...Good news the punk should be ok. Hit up Tekin and see what they say. |
11-25-2011, 02:15 AM | #3 |
Ok that's good. I really couldn't do anything more than laugh when it happened. I spend over $300 and then I go and wire the power leads wrong. Unbelievable!
11-25-2011, 08:10 AM | #4 |
Rock Crawler Join Date: Sep 2011 Location: truckee
dont feel to bad man, i pretty much did the same thing to a rooster crawler when i first got my crawler. i was reworking everything on the crawler because i got it used and it was set up poorly. some how when i was setting up the steering i hooked the battery up to the motor leads off the esc and poof. BUT... i know i will NEVER do that again |
11-25-2011, 08:45 AM | #5 | |
Live & learn. | |
11-25-2011, 09:03 AM | #6 | |
11-26-2011, 06:50 AM | #7 | |
Newbie Join Date: Oct 2011 Location: eastern sierra
11-26-2011, 07:34 AM | #8 |
| No problem, part of the use of a forum is to "hopefully" learn from other peoples mistakes.
11-26-2011, 08:41 AM | #9 | |
It's like wearing safety glasses. Oh sure I only gotta grind off a little tiny bit for a second, no need for glasses, then WHAM!!!! right in the eye. Been there twice. | |
11-26-2011, 08:56 AM | #10 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Yes...safety glasses are a must....happened to me yesterday....aluminum shavings in the eye from my dremel.... Deans and multicolored wire help me....I think we've all been their at one time or another |
11-26-2011, 09:28 AM | #11 |
| Last time it lodged itself into my eyelid which naturally became infected and turned into a huge nasty mess of an eyelid that kept oozing copious amounts of ooze. I'd wake up in the morning with my eyelid glued shut. Eventually my kick ass body worked the piece out in the form of some nasty blood filled puss sack I yanked off the inside of my eyelid. That's when I said, "Alright!!! I wear the stupid safety glasses."
11-26-2011, 03:41 PM | #12 |
^ Yeah I've been there I got a grinder shaving in my eye, and then had to have it scrapped out by a 4" long needle, not fun. I got my berg running, bought another FX-R, LHS was having a tax free and 10% off sale, I should of bought more stuff, quite a sale. Got an FX-R and the hotwire for $115 out the door. Now I just need to figure out how to get my DX3S to switch the Punk Dig switch properly |
11-26-2011, 03:58 PM | #13 |
Glad to see you're not throwing stuff Diablo |
11-26-2011, 04:01 PM | #14 | ||
On the DX3S, unfortunately it doesnt have a 3 position 3rd channel only two position. You wont be able to have 4wd and both front and rear dig on the standard punk, you need to choose one or the other (easy choice). What you will want to do is set one sides EPA (end point adjustment) down low so that the punk sees it as centered. Then just max the other side out so that the punk realizes that it isnt centered, now test it out and if you have rear dig rather than front then you just reverse the 3rd channel. | ||
11-26-2011, 04:01 PM | #15 | |
Quarry Creeper Join Date: Dec 2009 Location: Tehachapi, Ca
11-27-2011, 08:42 AM | #16 |
Newbie Join Date: Nov 2010 Location: Santa Clarita
I've smoked 2 esc in a span of 3 weeks. Now I have to send both for out of warranty service . Both were wired correctly and ran with a great battery. Went testing on the street after some adjustments and then "poof"!
11-27-2011, 06:15 PM | #17 | |
POSTCLANKER Do I know you? How do you know I throw things hahaha, you are in my back yard I live in Los Gatos. | |
11-27-2011, 06:49 PM | #18 | |
Los Gatos huh.....you should join us when you can....we hang out in RTLC southbay rocks thread Http://www.rccrawler.com/forum/calif...ht=Postclanker Last edited by Postclanker; 11-27-2011 at 07:01 PM. | |
