11-26-2011, 03:42 AM | #1 |
Rock Crawler Join Date: Sep 2011 Location: FNQ Australia
| Savox wierd behaviour
I have killed quite a few servos over the years but my savox sc 0251mg is doing something I havent seen before. It seems like the pinion on the motor is spinning . Fitted on a Wraith it will not turn the wheels at a standstill on the ground, I can hear the motor spinning , no gears crunching . Lift front wheels off the ground , works as normal. At moderate speed it works fine turning full lock to lock . It still centres properly . At the moment I have replaced the servo with another one and wondering if it is worth fixing . Maybe a drop of CA on the pinion ? could a slipping pinion be the problem ? Thanks for any suggestions. |
11-26-2011, 06:03 AM | #2 |
Broken tooth in the geartrain or the servo arm is slipping on the output shaft. That is what I'd check first. |
11-26-2011, 06:58 AM | #3 |
| thanks for a few clues , I have an integy 2 bolt clamp-up style servo arm and all the teeth are good on the output. I just took the cover off to look for any filings etc but all looks clean. I did notice a metal insert in the secondary or idler gear in the middle of the brass gear , I am wondering if this is the culprit .I cleaned it with cotact cleaner and put a drop of bearing retainer on it , whether it does any thing I'll find out in the morning.
11-26-2011, 07:32 AM | #4 | |
If this is an older servo (lots of runtime) the locating holes for the shafts may be getting worn out, thus allowing a gear skip. Granted, broken/missing teeth or worn holes sometimes means the servo arm doesn't return to center. | |
11-26-2011, 09:56 AM | #5 |
Quarry Creeper Join Date: May 2008 Location: Colorado Springs
Had this happen to one of mine. It was the shaft. Luckily my LHS just swapped it out for another.
11-26-2011, 01:49 PM | #6 |
Bingo ! after letting the bearing retainer dry overnight , I put a drop of CA on as well , it worked for about 3 cycles before the glue let go . Now that I have screwed with it there is no warranty, the servo is about 1 month old. My next step is to try to secure it permanently , I'll try to post a photo later , I'm going SC racing now.
11-26-2011, 02:38 PM | #7 | |
If nothing else, they may send a new shaft for free. If you want to make a permanent fix (provided you don't try my suggestions or you get blown off), I would look to see if there is a way to stake the gear to the shaft, maybe using a small center punch. Oh, have a great SC race. | |
11-26-2011, 09:15 PM | #8 |
yeah good idea , I'll try Savox its worth a shot , nothing to lose ! I was thinking the exact same repair method with a punch. Actually I thought first to try and drill a hole 50/50 in the shaft and gear and pin it but because of different metals the bit would go straight into the softer brass first . The SC racing turned into a practice / bash session at the track due to lack of numbers , still bloody good fun tho. |
11-27-2011, 11:05 PM | #9 |
Quarry Creeper Join Date: Oct 2011 Location: Georgetown, On
sounds like when my 5645mg flattened 3 teeth in the center position. works great in the air, doesn't on the ground. its out for warranty now.
11-27-2011, 11:09 PM | #10 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
I have seen and returned a Savox that had the pinion break on the motor before, it would work sorta under no load but was useless once anything was attached
11-28-2011, 02:34 PM | #11 |
I sent Savox a note explaining what had happened and what I had done , Joel at Savox has sent me out a new gear set to try and get it sorted out . Fantastic service !
11-28-2011, 07:17 PM | #12 | |
Please keep us posted. | |
11-29-2011, 04:18 PM | #13 |
| this is a bit different , it wont turn the wheels on my wraith at a standstill but while its moving its fine , reaching full lock, kinda like a slipper built into my servo ! NOT the hot setup for crawling !
12-19-2011, 01:54 AM | #14 |
| Re: Savox wierd behaviour
After a near record 3 weeks for my box of new gears from savox to arrive , they are installed and working fine. ( USA to Australia !) The culprit was the skinniest gear in the middle , the brass gear that was pressed into the steel one had come adrift . Massive thanks to savox for their service ,a quick note to them and the parts were in the mail , highly recommended. |
