11-27-2011, 07:12 PM | #1 |
Pebble Pounder Join Date: May 2011 Location: Decatur
| 4pl glitch
This is on a wraith I just installed a cc bec everything works like it should when I go from stop to full throttle it sputters and the receiver goes from green to red to green to red but if I roll into it it does fine. Any ideas From a misused and abused I phone |
11-27-2011, 07:26 PM | #2 |
What mah & "C" rating is your pack? Did it do this before you added the CC BEC? |
11-27-2011, 08:01 PM | #3 |
| This is what I put in and no it didn't glitch befor From a misused and abused I phone |
11-27-2011, 08:22 PM | #4 |
What mah & "C" rating is your pack? What radio do you have? What ESC? Is your RX near the ESC or the BEC? There have been some issues with a couple of ESC's & CC BEC's, I believe the RS running firmware V2.12 is one. |
11-27-2011, 09:56 PM | #5 | |
Futaba 4pl Novak rooster crawler Yes the esc is next to the rx but I've had no problems Befor and no the bec is not next to it From a misused and abused I phone | |
11-27-2011, 10:24 PM | #6 |
Most packs will have a series of numbers on them, my 2.2 comp packs are: 3S 1350mah 45C The 3S = # of cells The 1350 = mah capacity (how long it will run) The 45C = how fast the power can come out of the pack You could try recalibrating the ESC to the RX, otherwise I'm stumped for now. |
11-27-2011, 10:38 PM | #7 |
Quarry Creeper Join Date: Dec 2009 Location: Grass Valley Ca
11-27-2011, 10:40 PM | #8 |
11-27-2011, 10:50 PM | #9 |
Quarry Creeper Join Date: Oct 2011 Location: Georgetown, On
11-28-2011, 06:34 AM | #10 |
Just got off work will try all suggestions and let ya know the results thanks for the help From a misused and abused I phone |
11-29-2011, 05:16 PM | #11 |
Ok red wire out check Cc bec away from rx check All wires were they should be check Running and operational check Still glitching check but not as bad It's like the whole thing is loosing power even the lights flicker on and off From a misused and abused I phone |
