11-27-2011, 09:02 PM | #1 |
RCC Addict Join Date: May 2010 Location: So. Charleston. Wv
| DX3R help
First off i got this dx3r used with no manual. i got on theyre website and read the manual. i got everything hooked up bound, and when i turn the rig on it acts like i have the throttle on. going crazy. i adjust the controller settings and it helps but goes faster in reverse and slow forawrd I dont guess im doing something right. kinda getting ticked off about it. some help would be nice and some walk through trouble shooting! Thanks for help since im a airhead |
11-27-2011, 09:04 PM | #2 |
I wanna be Dave Join Date: Jun 2006 Location: Ukiah
Sounds like you need to program the ESC now
11-27-2011, 09:17 PM | #3 |
See ive done that also. sorry didnt add to the OP It steers how it wants too. If i reset everything would that help? |
11-27-2011, 09:19 PM | #4 |
Quarry Creeper Join Date: Oct 2010 Location: Building stuff in the basement
Re-bind it. Mine did the same thing when i first got it. I had to bind it a couple times. A year later it still works perfect.
11-27-2011, 09:26 PM | #5 |
Sounds like the ESC was not correctly calibrated, what ESC is it? As to running faster in one direction, it may have timing in the motor, but may be for reverse. What motor do you have? |
11-28-2011, 07:43 AM | #6 |
I'll bet you used the reset function to change the model information, right? If you did that then you also need to reset the PARAMETERS. When in parameters cycle the steering from lock to lock and the throttle from full forward to full brake/reverse. This is what is throwing everything off. Don't listen to all these "experts". They miss this one every time. |
11-28-2011, 10:46 AM | #7 | |
11-28-2011, 10:51 AM | #8 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
you have your throttle trim set to zero and endpoints at 100% on the throttle chanel?
11-28-2011, 11:55 AM | #9 |
11-28-2011, 11:55 AM | #10 |
11-28-2011, 01:36 PM | #11 |
11-28-2011, 06:44 PM | #12 | |
Rock Crawler Join Date: Dec 2007 Location: 10 a see
