12-02-2011, 11:12 AM | #1 |
Rock Crawler Join Date: Oct 2010 Location: triad
| wiring help, MOA + dig switch + MMP
Just got my new crawler in and trying to wire this thing up. I've done got confused The MMP instructions say "High Power Brushed Motor Mode: Connect all three of the ESC wires to the negative side of the motor" Here is what i "think" i need to do: *Wire the + front motor wire to the + "motor 1" location on the dig. Wire the - front motor wire to the - "motor 1" location on the dig. *Wire the + rear motor wire to the + "motor 2" location on the dig. Wire the - rear motor wire to the - "motor 2" location on the dig. *lastly, wire the + "esc" from the dig to the "A" post, then wire the - "esc" from the dig to the "B" post? Does that sound right? Last edited by concretejungle; 12-02-2011 at 11:20 AM. |
12-02-2011, 12:46 PM | #2 |
1-I think I would stay away from the "high power brushed mode" in your setup. 2-You will need to swap the + & - for the rear motor (it has a reversed rotation from the front motor) 3-Make sure the motor timing is "0", at least for now. Otherwise, I think you're OK. |
12-02-2011, 01:23 PM | #3 |
Charlie, thanks you are correct about staying away from the high powered mode. I realized that after a little more reading. So i have it wired up and the steering works, the dig works, but it aint going no where. The funny thing is the lights on the ESC when i pull the throttle down go green like they are supposed it, and it lights red when i hit reverse, but no movement at all. It also isn't chiming like it did when it was on my losi. I plugged it in using the castle link and switched it to brushed mode. Anything else i should look for? |
12-02-2011, 02:23 PM | #4 |
Did you calibrate the ESC to your RX? That would be the first thing to do.
12-03-2011, 09:55 AM | #5 |
on the mmp for brushed you use the A and C posts NOT B, that should make it run
12-03-2011, 11:07 AM | #6 |
12-03-2011, 01:04 PM | #7 |
| i dont recall that problem with my mmp and its had every firmware they released on it. its always used the red(A) and black (C), i know some of the other esc had that bug like the mamba 25
12-06-2011, 06:41 AM | #8 |
