12-02-2011, 04:23 PM | #1 |
Rock Stacker Join Date: Sep 2011 Location: over seas
| Steering servo for Wraith
i have had my Wraith for about 5 monthes (outta commision for one) and the steering servo is not moving the front wheels like it used to. How long do they usually last and whats the best replacement for it? Thanks in advance for the help.
12-03-2011, 06:18 AM | #2 |
Rock Stacker Join Date: Apr 2011 Location: Central, KY
My RTR servo lasted almost 2 battery packs. Must folks like a 300 oz servo on a wraith. I personally prefer a 400 + oz servo on a Wraith. Check out the Wraiths beginners guide & some Wraith build threads. There is some really good info out there.
12-03-2011, 06:36 AM | #3 |
I don't know how long the original servo will last, there are many factors that will determine this. If you up the torque, you will likely need an external BEC when you get near/over 300inoz. If you run a Holmes Hobbies BRXL, you can get away with just it's own internal BEC. |
12-03-2011, 06:39 AM | #4 |
Rock Stacker Join Date: Nov 2011 Location: Claremore
I use the JR9100T in my Wraith. You can use it without a BEC if you choose, and it doesn't cause any problems. It's a really strong servo and reliable. I've got 4 or 5 of them and I've never had one fail. Two are almost 2 years old.
12-03-2011, 01:41 PM | #5 |
Newbie Join Date: Jun 2004 Location: Lindsborg Kansas
Mine has had about 10 packs run threw it. its starting to get weak and the horn has alot of side to side movement in it now. Going to get a servo of atleast 300oz but probably get a 400oz one.
12-03-2011, 01:43 PM | #6 |
12-03-2011, 02:34 PM | #7 |
| +1 on the external BEC, when I installed my last servo, I unplugged my CCBEC Pro just to see what would happen. My 416 oz. Savox browned out in less than 30 seconds! I have used an external BEC for the last 2 years or so, looks like that will not be changing!
12-03-2011, 02:41 PM | #8 |
Newbie Join Date: Oct 2011 Location: Akron
I've had great luck with the T-Pros from hobbypartz they've got plenty of torque and they center pretty decently.
12-03-2011, 02:51 PM | #9 |
Yea I put a cc bec in my truck when I first got it because I'm running a 3s lipo
12-05-2011, 04:10 AM | #10 |
thx guys this helps alot im gonna pick one up shortly ill use the stock till it compleatly dies.
01-12-2012, 07:25 PM | #11 |
Newbie Join Date: Jan 2012 Location: pompton plains
| Re: Steering servo for Wraith
i need an upgrade nothing to crazy just better than stock if u know any let me know thanks
01-12-2012, 07:34 PM | #12 | |
| Re: Steering servo for Wraith Quote:
Pompton Plains, you should get on www.GSRCRC.com, my son & I are ~10 miles from you. | |
01-12-2012, 07:37 PM | #13 | |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
Sent from my highly abused iPhone using Tapatalk | |
04-27-2014, 09:54 PM | #14 |
Pebble Pounder Join Date: Mar 2014 Location: U4IA Oregon
What determines if it needs a bec or not? I would like to get a replacement servo for my wraith without needing a BEC
04-27-2014, 11:02 PM | #15 |
Newbie Join Date: Aug 2005 Location: Douglas, WY
| Re: Steering servo for Wraith |
04-28-2014, 03:46 PM | #16 |
So for the wraith any servo with more than 132 OZ of torque will require a BEC? If I purchase a servo and bec how complicated is the install 1 to 10 ?
04-28-2014, 04:34 PM | #17 |
Rock Stacker Join Date: Apr 2014 Location: Mobile
I do not have one yet, but I have read alot on here and it seems like the Solar D772 is a good economical choice.
04-28-2014, 05:17 PM | #18 | |
No one is making you do anything. But it is highly recommended as it takes the load off of the ESC and Receiver and puts it directly on the BEC. Your steering performance will be alot better. I have just gotten mine and I am awaiting on my Solar D772 servos in the mail to put them in. I set the voltage to 7.5 because that was my option for the solar. | |
