12-04-2011, 05:33 PM | #1 |
Rock Crawler Join Date: Oct 2011 Location: smithville
| Thunder ac6 connectors
All i hear is great thing about this charger so i decided i think i was gonna get this one, but i think it comes with a banana connector. Are there any banana to deans connector adapters out there? If not could i cut and solder my own connectors on to both the battery and charger? Thanks so much
12-04-2011, 05:54 PM | #2 |
i had the same issue so i removed the bannana conector and soldered on a deans. same with the battery. im sure many people do it. |
12-04-2011, 06:00 PM | #3 |
Yes, with the charger unpowered, you can cut off whatever connectors are on there and solder on what you need. Balance ports are the same, but be careful when you do the battery end as the connections are live. |
12-04-2011, 06:57 PM | #4 |
Quarry Creeper Join Date: Dec 2010 Location: gastonia
I would suggest cutting off a non used connector...never know when you may need a old nanner connector for some odd reason |
12-04-2011, 06:59 PM | #5 |
Are there any adapters tho?
12-04-2011, 08:01 PM | #6 |
Rock Crawler Join Date: Mar 2006 Location: Benson,NC
You can get a tamiya to deans connector and your charger should come with a tamiya lead.
12-04-2011, 08:37 PM | #8 |
Yea thanks i'll check that out
