12-05-2011, 09:57 AM | #1 |
RCC Addict Join Date: Nov 2011 Location: the not so white north
| up in smoke
One of my tekin FXR's went up in smoke after about 45 mins of play time. I have been using my xr10 for about week with no issuses. Was up on some rocks when it started to act funny by jumping forward and kinda glitching. So pulled the battery (3s 1300mah 25c) checked the power seen it was low. Put a new one on with full charge and esc goes up in smoke and toasts the battery aswell. Have used both battery's before with no issuses but this was the first time I had run the rig for more the 20-30 mins. I can't find anything that shorted out and like I said have it used it several times before with no electrical issuses. Anyone know why this happened? Did it fry my other fxr aswell? I don't want to go buy another and have this happen again. Or do you reccommend going to a different esc? Any help would be very much appreciated!!! XR10 dual fxrs cc bec futuba 4pl 45t rockstars Hitech 7954 |
12-05-2011, 10:56 AM | #2 |
1-I wonder if the ESC was getting too hot due to runtime? 2-I see no issues with your pack of choice (I would like to see a bit higher "C" rating) 3-Are either axle binding now? 4-No clue if the other FX-R toasted....power up & check. 5-Did the motor get real hot? 6-Is the LiPO cutoff set for 3S??? The ESC should stop before getting the pack too low. 7-Did the rig/ESC get wet? I usually run dual Mamba Max ESC's, but one died recently (I ran it almost a year & it was used when I got it). I switched to dual FX-R's on a 2.2 Bully MOA. I usually run 3S 1350 45C LiPO packs. No issues thus far, the FX-R's are considered a decent ESC to use. |
12-05-2011, 11:32 AM | #3 | |
No the motors were not hot at all and the rig has never been wet. Neither axle was bound. It went into lipo cutoff I assume thats why it was jerking and loosing power. Pulled the battery and check power level and it was dead. Esc is set for 3s via hotwire. Grabbed same battery type but charged and plugged it in put it on the ground and smoke, quickly unplugged and the battery had expanded and leaking, the esc was smoking and hot. Battery wire when i unplugged the first one was not noticably warm or hot. But the second battery very hot. I have used both batteries before with no issuses. The run time must have something to do with it. I know size is an issuse with the xr10 but can I run dual HH BR-XL's instead of the fxrs? They are basically the same price. If I have to buy 2 new ones that is. | |
12-05-2011, 11:34 AM | #4 |
Did your FXR have a cap?
12-05-2011, 11:38 AM | #5 |
12-05-2011, 01:24 PM | #6 | |
Since dual FX-R's worked, dual anything would likely work. Stupid question, the 2nd pack wasn't reverse wired, was it?? | |
12-05-2011, 01:48 PM | #7 |
Nope, I had used both packs previously with no issuses. This is why I am completely lost to what has happened. This is my first crawler and this has really put a damper on me wanting to spend anymore money on this hobbie as 15-20 mins play time just is not gonna cut it for the amount of money i have dumped into this rig. I bought everything listed bnib and haven't cheaped out anywhere. Have the vanquish motor and trans case, upgraded gears, stage 3 axial links, if my wife knew I have dumped this much into it and haven't even had a day of fun with it she would flip!!! I just do not want to shell out another $120 (hopefully only 1 needs replacing) on another esc and have some stupid crap like this happen. I am really kicking myself for not just getting an ax10 as in my group of crawlers I am the only xr10 and i'm the only one having issuses... The ax10 seems more reliableand way less issuses!!! |
12-05-2011, 01:48 PM | #8 |
| x2...Did you somehow plug it in backwards?
12-05-2011, 02:30 PM | #9 |
12-05-2011, 04:23 PM | #10 |
OK, to add some levity to this sad thread, I say, "Cheech & Chong!" mammoth, sorry to hear your issues, I'm really not picking on you, "Fecal material occurs" at times. We just had to ask the "stupid questions" because you never know on the Internet. |
12-05-2011, 04:27 PM | #11 |
Quarry Creeper Join Date: Oct 2011 Location: Georgetown, On
that sounds more like a bad pack then a bad esc...
12-06-2011, 08:40 AM | #12 |
| Now there is something that makes sense. I have never heard of a bad pack before. I had only used it once prior to this happening for a very short time then recharged it. I balance everytime I charge so I know the cell voltage was correct. How would you tell if it was a bad pack? Other then letting it blow your $#@* up. On the bright side 1 of the esc's is fine the other one that smoked i'm too scared to try and power it up with a lipo. It did however plug it into hotwire with no issues. Should I try and power it up? |
