Thread: What would you do?
Old 12-08-2011, 11:10 AM   #1
Default What would you do?
Hey guys.
I have a team checkpoint 1030 charger that I really like and has great specs.
But I am starting to get into lipos.
The charger will go up to 4s which is good enough for me.
Only problem is no internal balancer.
What would be better. Getting a external balancer or a new charger all together. I don't mind having to carry extra pieces or more wiring.
My budget would be under 100. So it would probably have to be a cheap charger.
Will an external balancer work just as well as an internal?
silver05 is offline   Reply With Quote
Old 12-08-2011, 11:36 AM   #2
I had an in-line balancer for awhile and it worked pretty well. It died after a few months though not sure why so I got the Thunder AC6 charger to replace them both. I suggest checking it out Thunder AC6 Smart LiPo Balance Charger/Discharger w/ AC Adapter for 1-6 Lipo/ 1-15 Nimh + USB to PC Software . For $45 it charges pretty much everything including 1-6s lipo charge/balance/storage options.
Operating voltage: DC 11~18 volts
Charge/discharge power: max. 50/5 Watts
NiCd/MH: 1~15 cells
LiIo/LiPo/LiFe: 1~6 series
Pb: 2~20V
Charge current: 0.1 to 5.0A
Discharge current: 0.1 to 1.0A
No. of cycle: 1 to 5 times
Battery data memory: up to 5 data
Weight: 260g
Dimension: 140*95*28mm
Computer USB port
Temperature sensor port
Built in AC adapter
SINister is offline   Reply With Quote
Old 12-08-2011, 12:08 PM   #3
I also have the Thunder AC6 (two of them); it's a very popular LiPo charger. It's very easy to use and the built in AC power supply is a big plus IMO.
Omega-Tron is offline   Reply With Quote
Old 12-09-2011, 11:21 AM   #4
Thanks for the replys guys
I will defiantly have a look at that charger.
Old 12-09-2011, 12:24 PM   #5
Proverbial threadkiller
Trubble's Avatar
I use a Team Checkpoint external balancer with my Onyx 230 charger, works just fine. Not sure I trust pushing 6 amps through a balancing tap, so I limit myself to 3 amps charge rate when using it as a charge-through. But used as an external while charging through the main lead, it also works well enough. If my 230 ever went belly-up, I'd keep an eye on Tower's, or A-main's 'scratch and dent bin' for a decent score on a 235. If I could actually afford to, though, I'd really love to pop for a Hyperion with a lot more power, (ie; EOS0720iNET3).
Trubble is offline   Reply With Quote
Old 12-09-2011, 12:51 PM   #6
Thunder AC6 is a great bang for the buck
never gave me a problem even switching between nimh and lipos all the time
i even take it out to the track with me
jokers_toys is offline   Reply With Quote
Old 12-09-2011, 12:56 PM   #7
x2 on a Onyx 230 charger and external balancer...have no problems.
squatch71 is offline   Reply With Quote
Old 12-09-2011, 09:40 PM   #8
I've got the onyx 235 and love it. I think you would like it and it's in your price range
steele42 is offline   Reply With Quote
Old 12-09-2011, 10:33 PM   #9
Same here, I think I paid 80 or 90 bucks for mine.
OKJeepin is offline   Reply With Quote
Old 12-09-2011, 10:49 PM   #10
+1 on the Onyx 235. I've been using this one for a few years now for NiMh and LiPos with no issue. Really easy to use has a dc connector for car battery connection charging.
I also have an old Hyperion EOS0606i charger. Works good too but I think it's more like 130 instead of 85 like the Onyx.
Sent from my iPhone 3GSlow but still works flawlessly.
AsILayDying is offline   Reply With Quote
Old 12-10-2011, 12:34 AM   #11
+3 Only problem I have with it is the fan make weird noises when I first start charging.
RusT808 is offline   Reply With Quote
Old 12-10-2011, 12:52 AM   #12
Trubble's Avatar
My 240 does that pretty bad, too.
Old 12-10-2011, 04:07 PM   #13
Thanks for all the help guys. Time for me to figure out what I want to do.
