12-08-2011, 04:15 PM | #1 |
Newbie Join Date: Nov 2011 Location: planet janet
| servos - I know nothing but project needs them
As some members may have read in a previous thread of mine, I have an Anderson M5 cross rc bike, I'm on a mission to make a dynamic rider for it, I have a basic prototype on the go already and my concern is all about servos, everything else is fairly straightforward. My issue is this; when there's no power to the servo, the servo allows 180 -ish degrees of rotation, yet when I power it up the servo anly gives about 60-70 degrees of rotation. When I move the rider he doesn't lean as far forward or back as I have the mechanical side of the system set up to achieve....regardless of countering forces etc. I am positive I am allowing enough margin from every angle regarding the mechanics of it and when the servo is powered down the rider can move through my desired movement range. How do I identify the correct type of servo for my needs? I know I need a very fast, strong servo that gives as close to 180 degrees rotation as possible but haven't a clue about servo specifications....clearly. Help me make a cool RC rider guys...please..... |
12-08-2011, 06:27 PM | #2 |
Most servos are factory set for 90* of powered movement. I also know that a lot of HiTec servos can go 180* of movement if you get the programmer. I would look at www.ServoCity.com and read some of the HiTec servo specs as well as programmer info. Whether other servo brands can be set for more movement or not I don't have that answer. Also, your idea of "strong" may be different from others idea. |
12-08-2011, 11:28 PM | #3 | |
RCC Addict Join Date: Jan 2005 Location: Germany north
How to: Improve Servo throw | |
12-10-2011, 01:29 PM | #4 |
Hi guys, thanks for replying Had a look at the servo throw thread, the dionysis stretcher looks to be the tool for the job here as I don't fancy getting the soldering iron and the calculator out LOL. I think a switch to 2.4 ghz is in order, none of my 27mhz stuff has epa adjustment and it could prove handy. |
12-10-2011, 01:37 PM | #5 |
Also, I already managed to relocate the servo and re-design the mechanism so that the short travel gives the desired movement range of the riders' upper body If I eventually get this little dude going the way I want him to then I'll make a video and post it in the video section, just in case anyone is into this sort of thing. Off axis backflips, extended wheelies, tarmac donuts; and most importantly - balance shifting when catching big air! this is all possible I believe - from a 2 channel rider Fingers crossed peeps. |
