12-11-2011, 06:20 PM | #1 |
Pebble Pounder Join Date: Jun 2011 Location: Columbus
| traxxas 2075
my dad just bought a traxxas 2075 servo and his first run out it lasted 20 minutes then it completely stopped working in his scx10. one of my scaling buddies has had one in his scx10 for about 6 months and is still working great. what gives and can it be fixed?
12-11-2011, 06:40 PM | #2 |
they pretty much kinda weak, all plastic gears, about 100+oz of torque and not that great for crawlers . you could rebuild it or you could get a better/ stronger servo. the only thing good about it is that its waterproof, but you can do that to any servo
12-12-2011, 10:54 AM | #3 |
its hard to say if it can easily be fixed, all depends what broke. if its a gear thats easy, but if just quit working all together, it is likely needing a new board or motor and that isnt hard if you had another servo to rob parts from but i would just get something better.
12-12-2011, 10:59 AM | #4 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
I have had a 2075 in my trail truck for quite some time. Probably 2 years actually. I have stripped out 1 set of gears. But this is in a trail truck, it will not last in a crawler. That's not it's intended purpose. Are you sure it's the servo and the receiver? |
12-12-2011, 11:09 AM | #5 |
Quarry Creeper Join Date: Mar 2011 Location: columbus
I use the plastic steering link, it takes away the stress from the servo.
12-12-2011, 09:44 PM | #6 |
Rock Stacker Join Date: Sep 2011 Location: Orlando
mine works great as long as Im not on the rocks, Ive only stripped gears onces but I maxed out the radio and was pretty rough on it, But I also had the one that came in my stock 4x4 vlx stampede go bad with in the first 30 minutes, never worked again. Ive had three of them since and all are still in good shape and working
12-12-2011, 09:52 PM | #7 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
I blew the gears out in mine the other day. I guess I'll be hitting up the LHS for a new gear set or grab a new metal geared servo.
12-13-2011, 05:51 PM | #8 |
Quarry Creeper Join Date: Aug 2011 Location: not south enough
I'm all mounted up for rear steer, for you guys that had one apart, what two wires do I switch to get it opposite the front, red and white or red and black? Thanks |
12-13-2011, 05:57 PM | #9 |
Pebble Pounder Join Date: Aug 2011 Location: San Antonio TX
If you call up traxxas, tell them it's stripped, they will send you a rebuild kit free of charge. I went threw 3 rebuilds till I got a metal geared.
12-14-2011, 11:42 AM | #10 |
| when you take it apart there are 3 wires going to the potentiometer and 2 for the motor. to reverse its direction you swap the motor wires and the 2 outside wires for the potentiometer
12-14-2011, 01:36 PM | #11 | |
by the way, it must have been just the cold weather or something because now it works again, the company he bought it from is sending him a new one just in case. | |
