12-11-2011, 06:46 PM | #1 |
Rock Stacker Join Date: Jul 2011 Location: downieville
| motor issue, whats up?
so i have some 35t motors from ckrc, and recently the front has been like stalling and not starting with out some help. so i pulled the old brushes and had the motor coms turned, got new brushes, oiled and cleaned housings. all looked good installed it all back together and does same shiot. i hooked it up to low voltage to break it in for 20 min and it feels like it is wobbling, not balanced or something. the bearings look ok ..and when i start the motor, i have to turn it with hand to get it spinning, anyone have any idea what could be the problem? thanks
12-11-2011, 06:47 PM | #2 |
and yes the timing is set at zero....
12-11-2011, 06:55 PM | #3 |
Sounds like "motor stall", usually the beginning of a dead/shorted winding. If it stops on the bad comm segment, it won't spin until you twist it a little bit. Since you did the most common "fixes" but still have the issue, you pretty much determined what is wrong. The only way to "fix it" is to replace the motor, get the arm re-wound or replace the arm. Sorry. |
12-11-2011, 11:18 PM | #4 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
^ x2 That's what it sounds like to me as well....The 'wobble' could be a comm plate has lifted. |
12-11-2011, 11:32 PM | #5 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Arm is shorted. The wobble you are feeling is the short happening, then going away so the motor jolts back into rotation. Get a new arm.......problem solved. Later EddieO |
12-12-2011, 06:04 AM | #6 |
ok not to sound to much like a newbie, but this is the first motor ive tried rebuilding, not sure what all the parts are and what and how. so when u say new arm....is this something i can do or have to get done? how do i know what one is bad and where do i get new ones and do i neeed any special tools...why would this have happened? the motors are only about 3 mo old.
12-12-2011, 06:41 AM | #7 | |
12-12-2011, 09:02 AM | #8 |
New brushes are typically the main item when rebuilding a motor. Sometimes the springs need to be replaced, along with adding some new washers to space the armature. Everything after that is just time and having the correct tools. A lathe for cutting the comm being the biggest one. Stalled armatures are actually pretty common, doesn't matter who made the arm....hand or machine wound, etc. Basically you shorted it by getting caught in a bind and tried to throttle out to the point the amp draw shorted the motor internally. It just happens.... In that event, you just swap in a new armature, put some new brushes in and break it in......then install. Later EddieO |
12-12-2011, 09:31 AM | #9 | |
You could contact Eddie0 about the motors you have and see if it's worth getting a new arm or having him do a service with a new arm. Some motors are inexpensive enough, it's cheaper to replace them rather than rebuild. I understand not everyone wants to replace "new" motors, but it happens sometimes. Try to NOT get them hot, they will last longer. Having them overgeared (for speed), binding axle bits, hard binds and trying to throttle out all generate heat. | |
12-12-2011, 11:01 PM | #10 |
Hey Eddie o do u want to look at them and fix it for me? I think broad makes this motor for ckrc don't they
12-13-2011, 07:06 AM | #11 |
How about a link to the motor from the CKRC site?
12-13-2011, 01:42 PM | #12 |
12-13-2011, 02:06 PM | #13 | |
| Quote: Off topic, did you notice the page title states "35T" but the description near the bottom states "55T"?? | |
