12-13-2011, 05:55 PM | #1 |
Quarry Creeper Join Date: Aug 2011 Location: not south enough
| what wire to cut?
I wanna reverse my 2075 traxxas steering servo, do I switch the red and white, or red and black wire? I think red and black, but I would rather know for sure before I start cutting. Thanks.
12-13-2011, 05:57 PM | #2 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
no wire cutting required, thats the OOOOLLLLLLLDDDDDDDD school way of doing it, you'll ruin today's servos doing that, there should be switches on your radio to reverse funtions, you will want to reverse the steering obviosly.
12-13-2011, 06:04 PM | #3 | |
I should have been more specific, I have a Traxxas 2.4 TQ radio, I am setting up rear steer, I only wanna reverse one. Thanks | |
12-13-2011, 06:13 PM | #4 |
Quarry Creeper Join Date: Dec 2010 Location: gastonia
should just be able to pull the out of the Rx plug and swap them..no need to cut still
12-13-2011, 06:18 PM | #5 | |
get your solding iron out! i'm not responsible if you screw it up. | |
12-13-2011, 11:20 PM | #6 |
Quarry Creeper Join Date: Jul 2009 Location: Buffalo area
I used one of these when I built a rig with rear steer. Didnt like the idea of messing around inside the servo because I might have needed it for another project some day. TowerHobbies.com | EMO0027 EMS Servo Reverser Futaba J |
12-14-2011, 12:16 AM | #7 |
Newbie Join Date: Mar 2009 Location: victoria
Couldn't you just switch the pins on the plug?
12-14-2011, 12:30 AM | #8 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
No just switching the pins on the plug will most likely fry it.... If you want to reverse the servo you need to either flip the switch on the radio to reverse the channel. Or you need to open up the servo and switch the wires on the servo motor and i'm pretty sure you need to switch the outer two wires on the Pot as well. |
12-14-2011, 01:40 AM | #9 | |
12-14-2011, 01:40 AM | #10 |
Thanks everyone for the input. Merry Christmas |
12-14-2011, 02:11 AM | #11 |
Quarry Creeper Join Date: Jun 2010 Location: Taos, New Mexico
On the traxxas website you can downlaod a PDF file for the instructions on how to configure your radio. You can reverse throttle, steering etc... It's fairly simple and understandable
12-14-2011, 07:16 PM | #12 | |
Quarry Creeper Join Date: Jul 2011 Location: Lake City, Fl
| Re: what wire to cut? Quote:
read above; he's doing this for rear steer, meaning he's got two servos. one needs to turn one way while the other needs to turn the opposite way... simply changing a setting on the transmitter will not solve his problem... and yeah just switching the two power pins around on the 3 pin connector will NOT do the job, as mentioned above. those two power pins supply voltage to the PCB inside the servo which control the servo's movement. hooking power up to it the wrong way will almost certainly kill it. you will have to either A) buy the servo reverser thingy above (ouch for $20 by the way...), or B) bust out the soldering iron and switch the wires around on the actual motor inside the servo and the potentiometer in there too, which might be hard to do on some because some servos have one or both of those two pieces soldered directly to the PCB itself instead of being remotely attached by wires Last edited by iamsuperbleeder; 12-14-2011 at 07:21 PM. | |
12-14-2011, 07:39 PM | #13 |
Rock Stacker Join Date: Aug 2011 Location: Canada
What about option C) redesign your rear steering mechanism so you don't have to buy a reversing unit or rebuild a servo? Simply by changing the linkage mounting points on the rear bellcrank or the rear uprights or knuckles (not really sure what vehicle this is) you can change the direction of the rear steering. |
12-14-2011, 07:41 PM | #14 | |
12-14-2011, 10:58 PM | #15 |
| Re: what wire to cut? |
01-01-2012, 06:48 PM | #16 |
bumping an old thread, but I saw this and it reminded me of this thread, so for future referance. (another inline servo reverser, much better then paying $16.99 for the other one, this one is $1.99) HobbyKing R/C Hobby Store : Turnigy Servo Signal Reverser |
