Rc4wd winch I am having problem getting it to not run in neutral. I can turn my radio on and off and the winch stops. After I use it the winch sounds like its rattling or slightly running but the spool is not moving. I'm stumped. If anyone has any advice please let me now. Sorry forgot to add I have a 4pl. Thanks |
Re: Rc4wd winch Quote:
Some zero creep controllers....try the search....it was a while back when I got mine.....no more creep though....hope this helps. It could be something diffrent though....just letting you know. |
Re: Rc4wd winch |
Re: Rc4wd winch 3racing is the way to go for future reference. rc4wd makes great things, but not winches. |
Re: Rc4wd winch A simple inline switch solved the issue for me. Cost $.50. Having a quiet winch priceless. |
Re: Rc4wd winch I'm familiar with heyok's winch controllers, but is that really needed for the RC4WD winch? Mine creeps, so I adjust it, then I operate the winch, and it creeps again. Is this really normal for these winches? It's pretty pathetic if this is typical. |
Re: Rc4wd winch what are adjusting?? not sure what you mean. another question on RC4WD winches. I have a 9300 brushless winch and controller....any idea what the max voltage the controler can handle?? instead of running two batteries, I am looking at hooking it to my main 3S battery. don't want to smoke another controler...when time allows (and funds) I am going with a heyok controler...but for now, I'm using this |
any one?? |
Re: Rc4wd winch Run mine off CCBEC set @ 6V with servo. No problem. |
Re: Rc4wd winch no bec |
Re: Rc4wd winch Run splitter off one of the radio channels and your esc will bump power down to acceptable level. It will be about 5.4V |
Re: Rc4wd winch I couldn't get mine to stop creeping either, bought hey OK no drift winch controllers now my rc4wd winches work flawless! |
