12-14-2011, 04:10 PM | #1 |
Rock Stacker Join Date: Nov 2011 Location: OVERTON
| Lipo Questions
i have a scx10 with a stock motor and a Traxxas xl5 esc. What i am wanting to know is what size lipo to run to get about an hours worth of run time? i know it will have to be 2s but how small of a mah rating can i go with? I would like to run as small of a battery as possible as my truck has a yota body with a drop bed & interior so space under the shell is going to be cramped. |
12-14-2011, 06:13 PM | #2 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
| Re: Lipo Questions
Well, I have seen a 1300mAh in one...seemed to be pretty good...with my 45T I get about 2 plus hours of trail time with a 3S 1300Mah You can go as small as you want, 850 I would think would be half hour to 45 min???? |
12-14-2011, 07:09 PM | #3 |
Quarry Creeper Join Date: Jul 2011 Location: Lake City, Fl
| Re: Lipo Questions
depends on a lot actually, mainly your gearing, motor, and driving habbits if it's geared too high and it's running say a stock 27t motor and your constantly punching full throttle, a 1000mah battery might last you 30 minutes but with that same 1000mah battery, you might get an hour if you had lower gearing, a 45t or 55t motor, and were easy on the throttle for the most part if it's the stock gearing and the stock motor, just with the XL5 ESC, I would try to fit at least a 1200-1500 mah battery it in. if you're willing to loose some wheel speed and put a smaller pinion on the motor, you could probably get an hour out of an 800-1000 mah battery |
12-14-2011, 07:15 PM | #4 |
| Re: Lipo Questions
Thanks for your help guy's im used to nimh and these are totally different so i figured somebody already had it figured out and i will end up going to a 45 to 55 turn motor once the stock one is done! |
12-14-2011, 07:26 PM | #5 | |
| Re: Lipo Questions Quote:
If you have been running 2000mah 6 or 7 cell NiMH packs, you will get a similar runtime from a 2000mah 2S LiPO. | |
12-15-2011, 01:07 AM | #6 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
| Re: Lipo Questions
you can get about 45mins to an hour out of a 850mah battery, thats running a 55t motor.. if your crawling a 55t is fine and gives you enough wheel speed. if your running trails with it then i say go a 45t and a little bigger battery something like 1000mah or so.. im planning on going lipo in the next couple of months myself and will be getting about 5-6 batts anywhere from 850-1500 mah... |
Lipo Questions - Similar Threads | ||||
few lipo questions | m1009cucv | Newbie General | 4 | 05-11-2011 05:25 PM |
lipo questions | silvermag | Electronics | 1 | 10-20-2010 10:14 AM |
Lipo questions | rmdesignworks | Electronics | 1 | 09-26-2009 07:59 AM |
lipo and lipo charger questions | OldShovelhead | Electronics | 9 | 07-11-2008 11:06 PM |
LIPo Questions... | PEDEcrawlerguy | Electronics | 2 | 05-10-2008 05:16 PM |
