12-20-2011, 05:10 AM | #1 |
Pebble Pounder Join Date: Jun 2010 Location: victorville
| Esc Stock mini losi
I have a mini losi crawler it is stock I would like to now if I can put my 1/10 scale speed control in my losi can I use my stock motor with the bigger speed and battery
12-20-2011, 06:05 AM | #2 | |
RCC Addict Join Date: Jan 2008 Location: Mount Juliet
| Re: Esc Stock mini losi Quote:
You can use the 1/10th scale ESC. Hopefully it is not very large as space is tight in those trucks. Also they typically weigh more as well. Without you specifying which ESC you are going to use, it is tough to say if it will fit easily or not. The motor should be OK with the larger ESC, but I would not recommend going over a 2cell LiPo, or 6 cell NiMH with that motor. Going to a physically larger pack will add weight, fitment issues, and probably issues with balance and/or center of gravity. Even if your 1/10th ESC may handle more volts....that motor may not. Remember that these trucks are very lightweight....adding more weight from electronics and batteries up high has a dramatic effect on performance. Last edited by xirtic; 12-20-2011 at 06:28 AM. | |
12-20-2011, 06:09 AM | #3 |
+1, if you can fit your 10th scale ESC in the rig you can use it. Space is your issue, the FX-R would be a good choice, a Mamba Max Pro or BRXL may be a very tight fit.
Esc Stock mini losi - Similar Threads | ||||
Torquemaster Mini w/ Stock ESC | SRQmini | Losi Mini-Rock Crawler | 8 | 03-19-2010 06:00 AM |
Mini Losi Stock Body Skins | Krawler Konceptz | Losi Mini-Rock Crawler | 0 | 09-27-2009 01:12 AM |
Mini T stock esc | rottenbelly | Non Crawler RC's | 2 | 11-15-2008 01:18 AM |
Losi Mini Crawlers now in stock | Reef | RCP Crawlers | 0 | 09-04-2008 03:43 PM |
baddest Mini-T motor with stock ESC? | JavelinSST390 | Non Crawler RC's | 7 | 03-11-2008 11:15 PM |
