12-21-2011, 06:22 PM | #1 |
Rock Stacker Join Date: Jun 2011 Location: Wenatchee, WA
| Help dont know what to replace!!!!
So im running a xr10 with 4pl, m2 and integy 35 turn motors. The car stated to just cut out the rear in 4 wheel whenever i came up to an opstical. Now it seams to randomly switch from 4 wheel to front only. witch makes me think esc. but them the rear motor seems slow and when up against a wall in rear only it wont even try to crawl at all just nothin so then i think motor. Not sure how to isolate the problem please help. Thanks |
12-21-2011, 06:24 PM | #2 |
| Re: Help dont know what to replace!!!!
try flipping the motor wires to the opposite motor to see if the motors are having issues or the esc is having issues. Sounds like esc to me but you wont know until you test some stuff out. |
12-21-2011, 06:37 PM | #3 | |
| Re: Help dont know what to replace!!!! Quote:
When you swap the ESC to motor wires, see if the issue remains to a motor or follows the ESC. My guess is mostly the motor or "maybe" clod stall. | |
12-21-2011, 07:05 PM | #4 |
Rock Crawler Join Date: Oct 2010 Location: NW Washington
Dude, bust out the cash and get yourself two qaulity ESC's and dump the M2. Then get a pair of brood motors. Just saying! See you at the next comp. Good luck on the electronics.
12-21-2011, 09:51 PM | #5 |
| Re: Help dont know what to replace!!!! |
12-21-2011, 09:52 PM | #6 |
| Re: Help dont know what to replace!!!! I know thats what i want to do but christmas has kinda killed me cash flow Hope to make the next comp for sure1
12-21-2011, 09:54 PM | #7 |
12-22-2011, 06:26 AM | #8 |
12-22-2011, 04:58 PM | #9 |
So did the switch and heres my conclusion. rear motor has little power and a definite bad spot on the com ESC has wicked bad claud stall and the drag brack is no longer working corectly Dont have the cash for all new electronics right now. But when i do, witch brood motor do you guys like? and whats the low down on the castle side winder? I know FXR's are bad ass but alittle curious on the castle stuff cause there BEC's are so good. |
12-22-2011, 06:45 PM | #10 | |
You should give EddieO from Brood a call, PM, or Email. Tell him what you are looking for in a motor and he can explain what will work best for you as he has many differant flavors of motor. I ran a pair of Brood 35T HHK, but then swaped to Brood 45T arms to better suit my driving style. Eddie can also rebiuld your motors for a very fair price. But, if your arm is shorted you will still be out a motor. No way to know untill you rebuild them and run them under load though. I had some motors that I though were shot, one would stall out and I had to spin it to get the motor rotating. Eddie rebuilt them and they are better than they ever were. You have a 4ch radio so dual esc's will allow you to take full advantage of your setup. But, a Punk dig works great and is a less expensive way to go with only one ESC. I run a Punk in my 2.2 with a FXR. It works so good I cant bring myself to pull it. I dont have any stall though either. Differant pinions front and rear help. Last edited by TedBull; 12-22-2011 at 06:47 PM. | |
12-22-2011, 09:08 PM | #11 |
Sidewinders are too big to run duals in my opinion. Go with FXR's or Mamba Micros. As far as brood motors I have a pair of 35t creep R/T, that is waht Eddie recommended for my berg. I have to say they have not let me down, these things are powerful! |
12-22-2011, 10:29 PM | #12 | |
Ya i will have to talk to him about what will work best for me as far as motors for my driving style. Do tell me more about this different pinions setup, im interested in what this will do to help stalling. Thanks for your in put | |
12-22-2011, 10:30 PM | #13 |
| Re: Help dont know what to replace!!!! So the micros work on the 1/10th scale stuff no problems?
12-22-2011, 11:05 PM | #14 |
I run 1 tooth smaller pinion in the rear. you could probably even go down two teeth in the rear. It keeps the front motor spinning faster and can help with stall. Its not as effective as being able to controll dual rate with dual esc's but it can help. Last edited by TedBull; 12-22-2011 at 11:08 PM. |
Help dont know what to replace!!!! - Similar Threads | ||||
Replace axial 2.4? | RCram | Electronics | 2 | 06-30-2011 10:28 PM |
Trying to replace servo.. | ChiefWigman | Losi Micro-Rock Crawler | 7 | 06-11-2011 04:27 PM |
Looking to replace my HR chassi, but which one? | LEWETHETIGER73 | General Crawlers | 0 | 11-24-2009 06:03 AM |
Upgrade or replace | Greatscott | Axial AX-10 Scorpion | 7 | 11-15-2009 08:29 PM |
Rovers (When is it time to replace them) | treday619 | Tires and Wheels | 20 | 07-28-2009 07:12 PM |
