Thread: gt3b w/hack 3rd channel issue
Old 12-22-2011, 02:44 PM   #1
Default gt3b w/hack 3rd channel issue
Can't seem to contact losikid.
Anybody know if the 3rd channel has 3 positions?
Or if u can mix channels?
I plugged a servo into ch3 to see how it worked
Servo went full lock. It did nothing when I pushed the button
on the grip. It did reverse to full lock when I rev ch3 in the menu
Also ch3 trim on grip trims ch1 not 3..
Ideas?
I wanna run a dual esc moa.
I don't mind using one esc and a punk dig.
just don't know if gt3b is capable....
elsewhere is offline   Reply With Quote
Old 12-22-2011, 04:52 PM   #2
Default Re: gt3b w/hack 3rd channel issue
just went thru the same thing, channel 3 button is just an on / off switch
crawlhog is offline   Reply With Quote
Old 12-22-2011, 08:53 PM   #3
hmmm.
know anything about channel 3 trim?
it trims channel 1.
i was reading the manual and it looks like i can run an MOA with dual escs on 3 channels but its still not really that clear..
seems i could run the second esc in the 3rd channel and use the trim to create a dig effect?
Old 12-22-2011, 09:49 PM   #4
You can mix dual esc's with the hacked GT3B. Easiest instructions are here:
GT3B Hack Question and Answer Thread
Post 342 in the GT3B hack thread. Set mine up this way and it works great. Except I set mine up for 10% increments and RES instead of MOM on CH3-Trim.
rhett314 is offline   Reply With Quote
Old 12-22-2011, 11:01 PM   #5
awesome.
problem solved! thanks guys!
Old 12-23-2011, 07:58 PM   #6
Got Worms?
the ch 3 BUTTON is just a two position. In order to get 3 position out of it you have to program it as a multipostion switch, physically change it to a 3 way switch, or get a wantmix 2p-3tp adapter. BUT...
As you found out your can map any of the switches to operate the 3rd channel (or a mix, or anything) in a 3 position or more manner
losikid is offline   Reply With Quote
gt3b w/hack 3rd channel issue - Similar Threads
fs gt3b setup after hack. foratm Electronics 32 06-27-2020 12:03 PM
gt3b hack programming WICKEDWOLFRC Electronics 2 11-05-2011 12:25 AM
Losikid gt3b hack review. WICKEDWOLFRC Electronics 0 10-16-2011 06:11 PM
GT3B Firmware Hack Kits losikid Vendors Electronics 0 07-29-2011 04:24 PM
4WS Set-Up? on GT3B 3rd Channel Solitude Electronics 15 07-17-2011 05:59 PM
