12-23-2011, 05:08 PM | #1 |
Quarry Creeper Join Date: Mar 2011 Location: Mn
| 645-mg Being weird?
Hey guys I have a waterproofed hitec 645 in my scx10. I put grease around the horn and used silicone to seal the rest. Anyway when I turn left it does it really slow but when I go right it does normal. When it's in the air it sometimes gets stuck for a second. Any thoughts? Thanks in advance |
12-23-2011, 05:18 PM | #2 |
Quarry Creeper Join Date: Jan 2011 Location: armstrong
| Re: 645-mg Being weird?
sounds like a bad servo board try a different servo also more info on you electronic set up might help more. Such as radio, receiver
12-23-2011, 05:35 PM | #3 |
Haha I tested it again and puff of smoke came out Sure enough water got in hopefully I can maybe get it workin
12-23-2011, 06:19 PM | #4 |
if it had a puff of smoke came out of it then it is shot cause the circuit board is fried it is easier to just by a new one had the same problem in my savage when I washed it
12-23-2011, 07:22 PM | #5 |
Once you let the smoke out, they're done. Replace it or have it repaired. Did it wash away all your punctuation marks too? |
12-23-2011, 08:21 PM | #6 | |
| Re: 645-mg Being weird? Quote:
OP, how old is the servo?? HiTec is pretty good about warranty, BUT, be truthful on what happened. You may get a free one, or a "cheap" replacement. I have no wish to "stick it to a vendor" because of my mistake. | |
12-23-2011, 08:25 PM | #7 |
Chances are good that the motor is still fine, so it would be a good candidate to make it into a servo winch if you would like.
645-mg Being weird? - Similar Threads | ||||
hitec 645 | wilrace | Electronics | 2 | 05-01-2008 10:06 AM |
645 mg glitching | hemorrageman | Electronics | 3 | 04-02-2006 11:40 AM |
HT 645 ?'s | twisted84toyota | Electronics | 3 | 03-15-2005 10:52 PM |
