12-25-2011, 04:31 PM | #1 |
Rock Stacker Join Date: Nov 2011 Location: united states
| Ax3 2.4
So I got my wraith about a month ago . Everything wad fine till last night. I got a 2 s Lipo in it. Ill drive it for 15 minutes and it starts to glitch and eventually it loses radio signal. I ran it in a ill bit of water but nothing to crazy. I know there was a post on here but couldn't find it. If anyone has some answers or ideas that would be great. Oh yeah merry Christmas . Thanks
12-25-2011, 08:18 PM | #2 |
| Re: Ax3 2.4
Did you try another pack in it? Did you try charging the pack that was in it? When it dies, is everything dead or only some things? What steering servo? Do you have an external BEC? |
12-25-2011, 09:42 PM | #3 |
| Re: Ax3 2.4
Well i only have that pack . I recharged it. When it died everything died. No bec. Stock servo. After recharged that pack it still did it again
12-25-2011, 10:07 PM | #4 | |
| Re: Ax3 2.4 Quote:
Did it last longer before?? Do all the LED's go out as well? Does the rig come back to life if you just pick it up? Is a LVC set in the ESC, if so, what value is set? | |
12-25-2011, 10:40 PM | #5 |
| Re: Ax3 2.4
It first would last for around 45 minute s. Now its not as long. Maybe like 20. The LEDs stay on and if I pick it up it doesn't change or come back to life. My buddy set the lvc but I'm not sure what its set to . Ill have to find that out.
12-26-2011, 07:50 AM | #6 |
| Re: Ax3 2.4
Do you balance charge? If so, what do the cell voltages look like when you start charging vs. end of charge? Since you are near GSRCRC, maybe borrow a pack from someone and see what happens. You may have a cell that is going flat. |
12-26-2011, 11:19 PM | #7 |
| Re: Ax3 2.4
I doubt its the radio...like your title possibly suggests. AFHDS is a brute on the frequency and it takes a strong signal to cause interference. I'm thinking its just a bad/cheap lipo and your hitting lvc then it recovers abit then you hit lvc again. |
Ax3 2.4 - Similar Threads | ||||
Need help- Binding ax3 tx to ar2 rx | Hoyta | Electronics | 0 | 12-09-2011 10:53 PM |
