Thread: esc & motor opinion
Old 12-26-2011, 02:30 PM   #1
Default esc & motor opinion
Would either of these systems work in a Losi CC.
Brushed No Limit esc & 19T brushed motor ?
Pinion recommendations
Or
Brushless 60A sensored esc & 10.5T motor ?
Pinion recommendations ?
thanks
rhino20 is offline   Reply With Quote
Old 12-26-2011, 04:38 PM   #2
Default Re: esc & motor opinion
Both of the would work. But Losi's eat brushed motors up unless you are on top of maintenance.
I would say say got for the brushless set up. As for pinion, i would say get the smallest you can get with a 10.5t motor...That's going to be pretty quick, most people i've seen run a 13.5t or slower.
You can gear it up if you want but keep an eye on heat on the motor & esc. Keep temps under 160°f/71°c and everything should be fine.
WIDELOAD is offline   Reply With Quote
esc & motor opinion - Similar Threads
Esc & Motor ?? SD333 Electronics 5 12-29-2007 04:31 PM
Need help motor & esc ????? mato_h Newbie General 5 11-06-2007 12:56 AM
