12-26-2011, 06:57 PM | #1 |
Quarry Creeper Join Date: Dec 2011 Location: marshall
| how do i mod a traxxas 2.4 radio
ok i'm trying to mod my traxxas 2.4 radio for 4 wheel steer but i do not want to have to run the rear steer via switch, i want to tie the 3rd channel into the steering switch and run a 3 position switch for servo reversing so i can run it just front wheel steer for center position or crab & 4 wheel for left and right but i can't figure out the steering switch, i can get the servo to steer and reverse but its not proportional and wont come back to center
12-26-2011, 07:11 PM | #2 |
| Re: how do i mod a traxxas 2.4 radio
Specifically, which Traxxas 2.4ghz radio??
12-26-2011, 07:41 PM | #3 |
| Re: how do i mod a traxxas 2.4 radio |
12-27-2011, 06:29 AM | #4 |
Quarry Creeper Join Date: Jan 2010 Location: USA
The 3rd, 4th, and 5th channels are not proportional.
12-27-2011, 06:40 AM | #5 |
| Re: how do i mod a traxxas 2.4 radio thats what i was thinking after messing with it last night, but still can't figure out why it it won't center back up, when i turn the wheel the servo turns let off nothing turn it the other way servo goes the other way let off nothing, really don't think its posible at this point my brain is smoking trying to figure this out, think i'll just stick with a switch for the rear
12-27-2011, 08:52 PM | #6 | |
| Re: how do i mod a traxxas 2.4 radio Quote:
The front steering should center if you let go of the steering wheel (the wheel is usually spring loaded to center). | |
01-03-2012, 08:01 AM | #7 |
01-05-2012, 08:50 AM | #8 |
Pebble Pounder Join Date: Nov 2010 Location: Simi Valley
in order for the rear to center, you need a 3 position switch or you have to adjust the servo horn.
01-05-2012, 07:15 PM | #9 |
| Re: how do i mod a traxxas 2.4 radio i think u are misreading the post, and i wish it was that simple but its centered from the start when i turn the wheel the servo turns, when i let off it does not center back up, this is not a case of newbisum, this is a case of understanding the circuitry of the radio to make it do stuff it was not intended for, im running the 3rd channel off the first channel switch (inside the radio the third channel on the cicuit board is wired to the first channel steering switch) so why will the first channel center back up when i let off and the 3rd channel won't
01-06-2012, 11:53 AM | #10 |
not sure why it doesnt center back. post a picture of the wiring and switch setup. you may need to re-do the wiring.
01-06-2012, 12:21 PM | #11 |
Newbie Join Date: Dec 2011 Location: Illinois
non proportional wont allow it to recenter everytime
01-06-2012, 04:43 PM | #12 |
It looks like the method you are trying to work out would leave you with just 3-positions without the ability to choose mirror, crab, etc. If just mirror or crab would do the job for you, maybe you could just plug the rear steer servo into the second CH1 socket on the receiver. This way, they will both to the same thing at the same time proportionally. If you would really like 3-position control of CH3, try to swap the wires between the red thumb switch and the original 3-position switch (there should be 3 wires going to each switch if I remember right). No steering wheel involved, but at least you would have control. |
01-06-2012, 06:19 PM | #13 | |
how do i mod a traxxas 2.4 radio - Similar Threads | ||||
4 channel traxxas 2.4 radio mod????? | GOODTIMESLA | Electronics | 1 | 09-09-2011 03:17 AM |
traxxas fm radio and traxxas waterproof esc help | jon1197 | Newbie General | 11 | 12-14-2009 12:34 PM |
Another Radio mod please | ElChupoCabre | Electronics | 2 | 11-17-2007 04:55 PM |
