fxr pro esc issues Ok got a fxr pro. Well 2 on a xr10. Couldn't get rear motor to do right so hooked hotwire up updated everything on both esc. Went to calibrate and front esc did fine. Rear turns on but has no arming beeps. Lights up fine goes to calibrate mode. Does Cali rate just without beeps if you would. But in the end no motor is spinning. Changed from ch4 to ch2 same thing. Any ideas |
Re: fxr pro esc issues You could try unsoldering the esc's from each other and calibrating one at a time. |
Re: fxr pro esc issues Not saying it wont work un soldering them but highly doupt it because the first few times I did it I had no problems. Hooked hotwire up and have problems. And like I said one esc did fine |
Re: fxr pro esc issues I use dual FXR's. Had same issue. I unsoldered them and calibrated them one at a time. It worked. Another thing you could try that made a differance with my Nomadio..On the transmitter I had the front motor set to "normal" rotation and the rear motor "reveresed" so I could get them both rotating foward. Only one FXR would calibrate. Then I swaped the motor wires to the rear motor around and switched the rear motor selection to normal on the transmitter. Then calibrated again and both esc's calibrated no problem. I did both methods and they both have worked with differant rigs and RX/TX. Try the motor selection first as its the easier. Make sure both motor rotation settings in the TX are set to normal. Swap the motor leads to make it happen if you have to. Worth a try. |
Re: fxr pro esc issues Ok. Good and bad news. Front one is doing it too. So think its software. What's the most updated fxrpro version and are any of you having problems with it. Thanks |
Re: fxr pro esc issues I am going to try unsoldering em tonight and programing one at a time. Other than that I guess esc is bad if that don't work huu? |
