12-28-2011, 07:10 PM | #1 |
Rock Crawler Join Date: Oct 2011 Location: smithville
| Tekin fxr wiring?
I have noticed that people using the dual tekin fxrs on moa's are wiring both esc's together. Do you have to wire it this way?
12-28-2011, 07:58 PM | #2 |
| Re: Tekin fxr wiring?
I run dual FX-R's in my 2.2 Bully. I "wire them together" in that they share a common connection to the battery (regardless of if it's dual FX-R's, or dual something else). The connection to the RX may be different. Does this help, or does it raise more questions?? |
12-28-2011, 08:10 PM | #3 |
It sort of helps but still leaves some ?'s. I will be using one battery but will be plugging each esc into a different channel. Does this help you at all?
12-28-2011, 08:27 PM | #4 | |
| Re: Tekin fxr wiring? Quote:
I go from the battery to a plug. From the plug, I run a red & black that connects to the inputs of both ESC's. Where the ESC's plug into (the RX) really has no bearing. In a true 4 channel RX (like a Futaba 4PL), follow Harleys set-up thread. I run dual FX-R's into a LosiKid WantAmix adaptor, thus I can control multiple things from a Futaba 3PM-x. | |
12-28-2011, 08:39 PM | #5 |
RCC Addict Join Date: Aug 2009 Location: Earth?
The battery + and - are the only thing on the ESC's that get wired together so when you plug up the battery it powers both ESC's.
12-28-2011, 08:53 PM | #6 |
^ That makes sense thats what i thought but i wasn't sure. I appreciate the help!
Tekin fxr wiring? - Similar Threads | ||||
Mamba Max , Tekin FXR or Tekin FXR PRO? | TheHeadHunter | Electronics | 21 | 06-21-2012 08:15 AM |
Wiring lights with tekin fxr and bec | SANTAVY1 | Electronics | 4 | 02-15-2011 07:50 AM |
Tekin FXR and FXR-pro ESCs in stock | JohnRobHolmes | Holmes Hobbies | 35 | 09-17-2009 09:40 PM |
