01-02-2012, 10:22 AM | #1 |
Newbie Join Date: Jan 2012 Location: My Town USA
| ESC cooked? newbe
Hi I have a Axial AX-10 with a AE-2 ESC. the truck worked fine yesterday. this morning I turned it on and it wont go fwd or revs. The steering works find. battery is good. tied pluging the motor direct to battery and motor runs. Is there a reset on the ESC?? this is my 1st RC so I'm trying to figure it out. Thanks |
01-02-2012, 10:30 AM | #2 |
Nobody Join Date: Sep 2008 Location: Maine
| Re: ESC cooked? newbe
Is the esc initializing? If your throttle trim on the Tx got moved the esc usually won't initialize when powered up.
01-02-2012, 10:36 AM | #3 |
hey ya the ESC makes the beeping sound and the green light is flashing. The trim on the controller hasnt changed. When I power the ESC red/green come on and make a couple beeps then just green |
01-03-2012, 07:51 AM | #4 |
please any ideas
01-03-2012, 08:26 AM | #5 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
Have you tried going through the setup again for the esc?
01-03-2012, 08:34 AM | #6 |
Manual for AE-2..... Axial AE-2 ESC Set-up and Programming Castle document....read the troubleshooting at the bottom.... Castle Creations | FAQ: 1/10th Scale Products Then get back to us... |
01-03-2012, 01:05 PM | #7 |
Rock Crawler Join Date: Oct 2011 Location: Warren
I am also new to all of these eletronic issues as I have just recently gotten into crawling, but the other day I ran into 2 issues that caused similar effects to what you are experiencing. My truck would go forward and reverse, but not turn. (Wires were worn through) The other Problem that I had was my connector coming from my esc (Same esc as you) is not functioning correctly and the wires were not making contact and it sounded like just about exactly what you were experiencing. Long story short. It never hurts to check the wires and connecters. Good luck.
ESC cooked? newbe - Similar Threads | ||||
Cooked esc | Tyler-brown | Redcat Crawlers | 5 | 12-19-2011 06:20 PM |
cooked Tekin 35T | BigSki | Electronics | 8 | 11-15-2010 04:24 PM |
I'm reasonably sure I cooked a battery, interested in knowing what went south | Slyp Dawg | Electronics | 2 | 07-25-2009 08:56 AM |
POORMANS HIGH LIFT ***DONE***and COOKED!! | twisted84toyota | 1.9 Scale Rigs | 33 | 02-08-2007 03:15 AM |
Cooked bearing | RD400 | Chit Chat | 8 | 09-18-2006 10:24 PM |
