01-03-2012, 07:00 PM | #1 |
I wanna be Dave Join Date: May 2010 Location: The east coast
| anyone running a sidewinder micro in a 2.2 shafty?
i've read a lot of people using the micros in 2.2 moa rigs and mini's but having found threads of people running it in a 2.2 shafty. i might be getting one in trade and i'm hoping to use it in my venom creeper sportsman running a 45t with 3s. what are peoples thoughts? will this esc hold up?
01-03-2012, 07:36 PM | #2 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
| Re: anyone running a sidewinder micro in a 2.2 shafty?
I have been running a micro pro this season on 3s/35t in my moonbuggy ax10 w no issues so I think you will be fine. Just watch temps at first. Mine rarely gets warm except in summer but its damn hot here.
01-03-2012, 08:42 PM | #3 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
have one in a MRC....not sure if it would hold up to 3S and a 45T.
01-04-2012, 04:20 AM | #4 |
| what's the difference between a sidewinder micro and a mambo micro pro?
it seems like the sidewinder micro and mambo micro pro have the same specs minus size. what's the difference between them? as noted in the start of this thread i'm wanting to know if the sidewinder micro could handle a 2.2 rig running 3s and a 45t motor.
01-04-2012, 05:17 AM | #5 |
I think the only differences are the added heat sink, and a bit more amps handled by the pro. I believe castle listes the different amp ratings on their site. Actually, they don't list the specs but do say Pro can handle more amps with improved fets. Both are rated for 3s |
01-04-2012, 05:39 AM | #6 |
Quarry Creeper Join Date: Oct 2011 Location: Waterford
I run two sidewinder micros in my xr10. They are awesome. I run a 3s 3500 mah lipo 2 45 turn integys And 1 7volt bec. I have ran this rig for at least 45 min with out stopping. There was no heat at all and no problems at all. I run this sol the time too and hard. So you are good just make sure you have the bec powering them. |
01-04-2012, 05:40 AM | #7 | |
| Re: anyone running a sidewinder micro in a 2.2 shafty? Quote:
01-04-2012, 08:25 AM | #8 |
Unless your are using dig, I think you would be fine, but if your worried, just go with micro pro. I have yet to have an issue with mine, and it has had some pretty good amp spikes in binds with no trouble.
01-13-2013, 03:43 PM | #9 | |
Pebble Pounder Join Date: Oct 2012 Location: Auburn CA
Why Do I need to run a bec to the esc? | |
01-13-2013, 03:58 PM | #10 | |
OP: I have run a Mamba 25 which is the same thing as a Sidewinder Micro in a Sporty with no issues, and use them in my Berg with 35 turns, just keep and eye on temps. If you over gear it you might have issues. Last edited by 666; 01-13-2013 at 04:00 PM. | |
01-13-2013, 04:15 PM | #11 |
I've got Sidewinder Micros in both my Scorpion comp rig, and my SCX conversion, both running the same 3S/1300mAh, with a Brood Apocalypse 35 turn in the crawler (2.2 w/t), and a Holmes 35 turn Torquemaster Pro in the SCX (1.9 t/w). I run a BEC at 7.4 volts in the comp rig with a HV servo, the SCX still has the AS-2 with a 6.0 volt BEC. Both are geared rather low at the stock Scorpions' 14/87 s/p. Both run fine. The one in the comp rig has gotten warm enough to wad the sticker up, but never quit running nor has it ever smelled like it was burning up. I think you'll be alright with a Micro and a 45 turn, though I do recommend watching your temps and if need be, gearing conservatively. |
01-13-2013, 04:54 PM | #12 |
Heck! I am running 2 mamba 25 on a couple supers with clod axles, with brushless revolvers on them over 4 years now, I doubt you would have any problems on you shafty, the difference if I recall correctly is that the smaller older mamba 25 were rated at 25amps and the micro is rated at 30amps, or somewhere along those lines.
01-16-2013, 04:05 PM | #13 |
Pebble Pounder Join Date: Nov 2010 Location: Harrisburg on the way to Wingate
Shafty= 1 ESC and 1 motor, MOA= 2 ESCs and 2 motors. No matter what, your running 1 motor on 1 ESC. Just my opinion.
01-16-2013, 04:14 PM | #14 |
The Micro Pro has the best bottom end throttle control I've ever felt.
01-16-2013, 08:52 PM | #15 |
I run one in my axial sporty with no problems. I have never had any overheating issues and I run a 30t custom Holmes motor
01-21-2013, 12:45 AM | #16 | |
True. But, in a bind, you put more load and stress on the 1 motor/esc combo pushing a transmission that pushes BOTH axles. In a MOA there is one esc controlling one motor pushing only one axle. Your going to get higher amp draws and temps out of the shafty. Correct me if I'm wrong all | |
anyone running a sidewinder micro in a 2.2 shafty? - Similar Threads | ||||
Mamba Micro Pro vs Sidewinder Micro | strawb | Electronics | 42 | 01-29-2015 07:24 PM |
sidewinder with a cc bec,works great but Can I swap it out for a Micro sidewinder? | username | Electronics | 3 | 04-04-2009 10:11 PM |
